negative spaces
I was looking through my old photo the other day and came across this piece that I built when I was trying to learn more about negative spaces. It started with the classic design of a goblet that when you view the negative space you see a human face. This led to more study.
A negative space is that area outside the turning that your mind still sees but maybe not your eyes, until you train yourself to do so. What we often perceive as a good form is often that way because the negative space outside the form is also a good shape.
For example when I make my Christmas ornaments I always play with the negative space created by the coves. If you look at the negative space it can be half a hollow vessel or half a bead. It really leads your eye in different directions depending on how you shape it. this helps your eye flow into the next element if or possibly the lines of 2 shapes merge outside the forms which helps them work together.
the same is true for convex surfaces. If you look at the negative space created by an ogee shape. A really good shape will look like a well designed vessel. In other words the negative space leads the eye as well as the positive or physical piece.
Negative spaces also work in dot patterns as viewed in the goblet on the side of the box in my piece. The dots create a face and the space creates the goblet. The opposite of the goblet inside the box. The closer the dots the darker the area becomes. The further the dots the lighter. This is of course how half toned images are percieved. You only have white and black in a half tone but by placing lots of black dots close together you get dark gray. less closely packed a lighter gray.
The Parthenon in Nashville which is a copy of the Greek building is a great example. The pillars outside are shaped and spaced so that the negative space appears to be a vessel.
If you really have trouble seeing the shapes created by the negative space try drawing the object and then shade in the negative area instead of the piece.
In this piece after I made the goblet people had trouble seeing the face so I created the box which made it easier to see. Then I added the faces to the outside playing with the negative spaces created by the dots. Then I wanted to play with offset turnings that also depend on negative spaces to make the profiles work so I created in my mind a man standing at attention. He started as an inside out turning that made the hollow shapes in his body. Inside out turning is also very dependant on negative spaces to create the profiles you see when glued back to gether. I built a bowl to go on his head to hold the box but that looked incomplete so I created another bowl for the top. This resembled a head to me and it needed hair and since I was turning miniature goblets at that time I added 77 of them to the top. I designed the goblets to not be in rows and then built a jig to go under my drill press to drill the holes perpendicular to the sides of the bowl. When I got finished I counted and said holy crap (or something like that) there's 77. So I worked out a way to make them quickly and got started. The I decided since I was losing hair I put one more on the bottom. I chose black and yellow for the piece because Contrast and color can also be help you see negative spaces so I wanted to play with how that works.
Anyway it was a fun project. I designed it when I went to my first AAW symposium. As you know there are something like 1000 pieces in the instant gallery and I wanted a piece that was different. I called this piece, Just another face in the crowd hoping it would stand out from the crowd. Well the work in the instant gallery is so awesome it really didn't stand out per se, it was just different. Still I had fun designing it and learning from the process.
