Be careful
Well I really wasn't in danger because my hands were well out of the way and my body was balanced. Apparently the bottom wasn't as flat as I thought it was and my blade wasn't as sharp as it should. So when the wood rocked a tiny bit and the blade was already trying to wander it popped the blade off the wheels.
The blade wasn't damaged and I wanted to save it even though it's getting dull. It's fine for cutting 6" deep bowl blanks just not good for 15". I drove chisels and wedges in until it popped the slab of wood off and I could retrieve the blade. It is a nice walnut crotch and I really didn't want to lose it.
So ideally you should make sure any surface touching the table is flat or has been wedged on a wooden sled to make sure it can't rock. And of course you should use a sharp blade.
