Veritas - Innovation in Tools
Coloring epoxy
Coloring epoxy
Coloring epoxy
Hal Taylor
Curious. Does it matter if one colors epoxy with oil based or water based like acrylic colors? I was sitting here thinking of trying to mix some metallic paints to see the effect, but I remember hearing somewhere to only use oil base paints. What's your experience?
Re: Coloring epoxy
Re: Coloring epoxy
cranskin
I use acrylic paint for my epoxy and have had no problems.
Re: Coloring epoxy
Re: Coloring epoxy
I've used both but oil base is easier to mix. I also use trans tint and tempera paint and india ink
Re: Coloring epoxy
Re: Coloring epoxy
For dead black or white I use premixed epoxy pigment.
For colors I prefer TransTint concentrate
For metal, I prefer metal powers that are available in colors from "white" to gold to bronze to copper. I've used molten pewter as a filler so long as the finish will be water-white.
Re: Coloring epoxy
Re: Coloring epoxy
jim breeden
John - I would think that an oil base tint would either prevent, or slow down, the set time of an epoxy. As in, oil doesn't mix with anything other than an oil base product.
Re: Coloring epoxy
Re: Coloring epoxy
Doug Wolf
I use "Pearl-Ex" metallic powders from Hobby Lobby.
Re: Coloring epoxy
Re: Coloring epoxy
Not that I can tell. I do assume that anything I mix with epoxy changes it somewhat so I often run tests to make sure it will still harden properly and I always assume it will take longer than normal. The only difference I've seen in water based paints or oil based paints is how hard it is to get the initial mix. Anything mixed at too high of a percentage can drastically change the epoxy but usually if you use concentrated colors it takes very little to get what you want.
My favorite is still the India Inks or Transtint.
Re: Coloring epoxy
Re: Coloring epoxy
Re: Coloring epoxy
Don't forget Inlace
Not only does it come in a lot of colors they also sell a lot of powders and chips that are colored and designed to mix with it.
Re: Coloring epoxy
Re: Coloring epoxy
jim breeden
I've been using the powered aniline dye designed for alcohol, and other non-liquid dyes. Been spooked about using any liquid type dye, thinking the epoxy might not set properly.
Re: Coloring epoxy
Re: Coloring epoxy
Jim,
The TransTint concentrates are pre-dissolved in alcohol and mix instantly with epoxy resin. It takes only a drop or two to get the color you want and will have no effect on the resin or its set-up properties.
Re: Coloring epoxy
Re: Coloring epoxy
Hal Taylor
Thanks guys. Had not thought of most of the suggestions.
Re: Coloring epoxy
Instant Coffee
Doc Green
Instant coffee works quite well and actually will dissolve in the epoxy. However, the color selection is limited: Brown.
Re: Coloring epoxy
Re: Coloring epoxy
Only takes a short while to do a test. I never just arbitrarily mix things with epoxy without doing a test to see if it's going to work. We don't know what brand epoxy you use or what brands of colorants. Any of them may work, or may not. Why take a chance.
Re: Coloring epoxy
Re: Coloring epoxy
jim breeden
Thanks everyone -time to experiment. 8)
Re: Coloring epoxy
Strait Line Chalk *LINK*
Craig Daymon
I've only used the black, and it worked great, but it does come in several different colors, including Red, Yellow and Blue. It's also cheap and the funnel nozzle of the containers makes it fairly easy to control how much you are adding to the epoxy. It's already very fine grained, so no need to grind it up any (as would be the case with wood shavings).
Sorry for the late reply. I read the first couple posts and it sounded like you were focused on dyes.
Strait Line Chalk
Re: Coloring epoxy
Jim Evans
Coloring Epoxy
Jim Evans
Same here, I use Pearl-ex all of the time and have had no problems.
Re: Coloring epoxy
George Balock
Re: Coloring epoxy
George Balock
The only problem I've discovered with using acrylic paint in epoxy is that the shrinkage is pretty dramatic. I had a piece that I finished and then noticed that the epoxy "patch" ended up lower than the surface of the bowl. To fix that, I fill with the epoxy/acrylic paint mixture and let the piece sit for a good while before I final turn.
