New Work Space
New Work Space
New Work Space
Steve Criscenzo
As I mentioned in my previous post, I just completed a rework of my shop space to accommodate my new dust collector. I took the opportunity to organize my turning area. I took the wall space that was freed up by moving the old dust collector and made new tool racks.
My tool racks are two piece units with a bottom shelf and a top guide to keep the tools vertical (not a magnet to be found). I have a piece of non skid shelf liner on the shelf to keep the handles from sliding around. I like this method for holding tools for several reasons: the tools are vertical, I can see the whole tool so there is no confusion as to which tool I am grabbing, and the tips are securely separated to prevent accidental bumping (which can destroy a carbide tip on Hunter or other carbide tools).
I had some shelf standards available from a previous renovation project so I used them to mount the tool holders so I could adjust the height and separation as required. I modified the shelf brackets to work with the narrow shelves and also secured the shelves to the brackets to prevent sliding and/or tipping.
The first photo is a wide shot showing the space. I took advantage of the 10 ft. ceiling height to mount the vacuum pump up high and out of the way. The controls and the switch are just to the right of the top tool rack. I also ran air lines to an overhead spool (out of the picture). I buy my sandpaper at the bulk bargain bin at the local Klingspore store and store the various grits on the clips hanging below the upper rack.
The second photo is a close up of the upper tool rack showing construction details. The third photo is a some found space next to the garage door that I hung peg board on and use for chucks, tool rests, and some measurement tools.
Still have a few more things to organize but I am back to turning and enjoying the new space.
Steve
Re: New Work Space
Re: New Work Space
George Hurlburt
Looks real good, nice and clean. Do you have horse pads on the floor? You did not show. I'm 5'8", not sure I could reach the top shelf where you placed more tools. What do you use for heat and cool?
Re: New Work Space
Re: New Work Space
Steve Criscenzo
It's only clean because I just finished a major clean up. I built vacuum ports into the new dust collector system so I am hoping it will be easier to keep clean.
My floor is concrete but I stand on a double layer of foam mats. Have several around the shop. Watch for the sales at Woodcraft.
I am 6'3" so reaching the tools is not a problem but because I used the adjustable shelf standards, they can be put at any height.
My shop is an attached 20x 24 garage. It is insulated and has conditioned space above. It also has an insulated overhead door with no windows. The overhead door is not particularly air tight but except for really windy days it does OK. In winter, I run a 1500 watt space heater and it will keep the shop at 60 degrees most of the time. There is so much thermal mass in the shop that it tends to temper the extremes (living in North Carolina also helps). The shop gets little direct sun so the summers are not bad. if it gets hot, I open the door. Using an Airstream helmet helps also when it get hot.
Steve
