New Dust Collection
Steve Criscenzo
Last fall, while preparing for a gallery show, I spent several long days in the shop finishing pieces. In spite of being very careful with dust control ( I wear an Airstream while turning and I try to collect dust at the source with a 2 HP single stage dust collector) I was still feeling the effects of the prolonged exposure to the shop environment in my lungs. Since I am looking forward to retirement (and spending much more time in the shop) in three years I decided that I need to upgrade my shop dust collection system. I had two primary criteria. Fist it had to provide HEPA filtration and second it had to have sufficient power to use with two ports open at the same time.
After much research, I decided to go with the 3 HP “V” system from Oneida Air Systems. The added power allowed me to move it the dust collector to the far side of the shop (much quieter) but this move required a major redesign of my shop. I decided to go with metal ductwork because I am comfortable working with it and the ability to use 7” and 5” pipe in addition to 4” and 6” made for a more efficient duct design.
I finally had to chance to give it a run today. It works great. The first photo is a picture of the unit utilizing the wall mount system. The second photo is a wide shot showing the two dust hoods I currently use at the lathe. The third photo is a close in view of the dust hoods.
I use both hoods for most sanding operations. The front on is a 10x4 vent boot with three rare earth magnets holding it to the lathe. It captures most of the dust coming of the front of the piece when sanding and can be easily moved out of the way when not needed. The rear (PVC) dust port has a magnetic base that I usually fasten to the banjo while sanding. It hangs on a hook on the back of the lathe when not in use.
Even though the lathe is at the end of a 40 ft. duct run there is ample air movement with both ports open. Both ports are connected to individual 4” flex lines coming off a 6” trunk.
I think it will make a huge improvement.
I will post pics of the shop redesign in a separate thread.
