Re: Follow-up on "something new"...Prism Paint *LINK*
Ed Davidson
It doesn't matter if the bottom is curved or flat. But you do need a sharp 90 degree edge at the top so the paint can have a containment-edge and make a nice straight border. Other than that, there's no further prep needed. The paint is very sticky and will adhere to just about any surface.
The thicker the paint is when applied, the larger the prism effects will become, so I pour it pretty thick. After the paint is fully cured (3 days), it will have shrunk to about half the height that you started out with, so no...it does not hold a dome shape. It'll actually end up concave shaped.
After it's cured, the paint has a moderately shiny surface, but I always add a coat of clear resin on top to protect the paint, and give it that real glossy (and domed) look. There's a link to the final-coat resin I use below.
Sun and Moon Glaze
