photo tent
photo tent
Keith Tompkins
photo tent
Keith Tompkins
Here is my new photo tent setup. My shell form was the first pic I took with it. Many thanks to John Lucas and Jamie Donaldson for all their help and patience in this area. My early images were BAD.
Re: photo tent
Ric Taylor
What is the Bottle Used For?
Re: photo tent
Keith Tompkins
Re: What is the Bottle Used For?
Keith Tompkins
Yes, for photographing my bottle stoppers...yeah, that's it!
Re: photo tent
Re: photo tent
darrin hill
where did u get the background from?
Re: photo tent
Keith Tompkins
Re: photo tent
Keith Tompkins
Hi Darrin,
B and H Photo in NY city. 1-800-947-9978, they also have an e-bay store.
Re: photo tent
Keith, move the lights to "unbalanced"...
JamieDonaldson
....positions, one high and the other low, to eliminate the dreaded "headlights" on a turning. It is often beneficial to move one further away to fill (soften) the shadows created by the main light. Play with this rig, and don't let the table top determine your light set-up. ;)
Re: photo tent
Keith Tompkins
Re: Keith, move the lights to "unbalanced"...
Keith Tompkins
Thanks Jamie, as always!
Re: photo tent
Keith Tompkins
Re: photo tent
Keith Tompkins
Darrin, I cut the background down to 24" wide...
Re: photo tent
Re: photo tent
Phillip Medghalchi
Keith, I have the exact tent, but my lights are not the same. I wonder if those make lots of different in picture quality?
I hope Jaime or John chime in. maybe I get a pic. of it tomorrow and post it.
Re: photo tent
Re: photo tent
I haven't read every one else's response yet but this is a classic example of how people use a light tent incorrectly the lights are too low, the same height and the same power. It gives the impression of 2 suns and we only have one in this soar system
Ideally you should have just one light up a d to the side so it lights the top and one side. If you absolutely need a second light it should be lower and weaker than the main light. The easiest way to make it weaker is to simply aim it less directly toward the tent or move it further away.
Ill try to answer more later. Gotta get moving to go look at a house this morning.
Re: photo tent
Re: photo tent
Lights only don't really make a difference it's the distance from the tent and of course the color temperature of the lights. Putting the lights close produces an uneven light and if its a glossy piece it leaves a wise hot spot. Moving the light back so it lights the top mostly a d one side gives a look that's more like a cloudy day which is why people started using the light tens in the first place m
The l main light should also be as far forward as possible to help light the front of the piece. The same with the fill light. You will probably need a white card to bounce light back into the front of the piece
One of these days ill do a video on shooting work but have way too much on my plate right now trying to find a place for Lucy and I to live and get my house ready to sell.
Re: photo tent
Alan Zenreich
Re: photo tent
Alan Zenreich
John expressed pretty much all I was going to say. I use two lights, one three times the power of the other.
Re: photo tent
Re: photo tent
Phillip Medghalchi
John, I again appreciate your reply, despite your busy schedule. I hope you can find a house suitable for you and Lucy soon (possibly with a bigger garage or workshop) Best of luck to you.
Alan. thank you too for replying.
Re: photo tent
Re: photo tent
I tried a light tent years ago and found it useful for jewelry. I used to teach using a light tent. However I find that I use a 12" reflector with a diffuser or a 20x24 soft box as my main light without a light tent. And the. Use a white reflector card. Most wood turnings can be photographed using one large main light and one reflector
Re: photo tent
Keith Tompkins
Re: photo tent
Keith Tompkins
Thanks John, See what I mean....Jamie and John are STILL helping me out! :)
Re: photo tent
What light bulbs did you use Keith?
Dick Coers
And did you buy that tent? My goal this year is to start a web page and list some jewelry on Etsy. So, I need to build a rig similar to yours. Sorry, I know the light bulbs have been discussed before, but just feeling lazy tonight I guess. Thanks!
Re: photo tent
Keith Tompkins
Re: What light bulbs did you use Keith?
Keith Tompkins
Hi Dick, I bought the whole contraption from B and H in New York. (see above for phone number) I didn't like the lights that came with the photo tent, so I upgraded. The whole setup cost less than $100.00. I'm happy with it.
Re: photo tent
for lights...
GaryG in MD
I have a similar setup and originally used to use the cheapo 500 Watt halogen "shop light" from the Big Store with a bounce card on the opposite side and sometimes a desk lamp balanced on top. Works fine, but the problem is heat.
I have switched to a rectangular bank of LEDs. Works great. Totally cold. Variable intensity with a dial. Cheap enough to buy more than one. Got 'em on Amazon. Works for hours off a standard video camera rechargeable battery. I'm sold. ...GG
An example: And this is the little one:
http://www.amazon.com/NEEWER%C2%AE-Dimmable-Digital-Camcorder-Panasonic/dp/B004TJ6JH6/ref=sr_1_1?ie=UTF8&qid=1421472918&sr=8-1&keywords=neewer+cn160
Re: photo tent
Re: for lights...
I buy my bulbs from either Alzo.com or bhphotovidio.com. I get FLD bulbs that are 5500K. That matched the daylight white balance setting on your camera.
Re: photo tent
Re: for lights...
The type of light doesn't really matter as long as you can white balance to it. It's more about the quality of the light. This can be achieved by using a fairly large reflector and then putting a diffuser over it. Or you can use a photo umbrella or soft box. I prefer soft boxes because you have more control of the light.
I just did an article for American woodturner on using typing paper and a standard household table lamp to shoot smaller work. Don't know when or even if Josh will use it but he liked the idea.
Re: photo tent
Re: for lights...
steve worcester
I haven't seen a final picture, but I would say a third light on the top tilted towards the camera, so you don't spill light on the background, of lesser wattage, would also work well
