ADVERTISE HERE - FREE TRIAL
hollow vessels
hollow vessels
hollow vessels
eliot feldman
I usually turn the outside first, hollow to the thickness I want, and then reverse the vessel to deal with the foot.
But I remember a video by John Jordan, I believe, where the outside was purposefully left too large for the bottom few inches. The inside was hollowed ( leaving too much wood for the bottom few inches) and the outside, where there was too much wood, was later reduced to the desired shape. I seem to recall John marking the final shape he wanted with a pencil, and then turning to this line. But now I can't get it out of my head that you can't do it that way because as soon as you begin to try to get to the line, the line will turn away and disappear. what am I missing, please?
Re: hollow vessels
Re: hollow vessels
Dick Coers
John will probably reply, but he did that because he had screws mounting the vessel to a face plate. The screws were outside the final shape of the form, he had to leave that material until he took it off the faceplate. It takes skill and mental visualization. You need confidence to know where that shape will end up. It always looks easy when done by such a skilled artisan, but when tried early in your skill building, you find out it is far from easy. It's the same for me when making spherical shaped hollow forms. You can't take the outside form all the way down to the final shape, or you will make it too weak and get chatter. So you turn where you can on the outside, then just anticipate where the form will end up when you do the hollowing. John taught me to keep a crisp corner where the outside shape meets the mounting material. It makes it easier to visualize where the final form will go.
Re: hollow vessels
Lyle Jamieson
Re: hollow vessels
Lyle Jamieson
I always turn hollow forms in stages so I don't have vibration problems and I don't want to use a steady rest. Penciling in the shape with the lathe off will help you see where the bottom of the vessel will be while the waste wood is still in the way. But the pencil line will not be much help in turning the shape of the final stage.
Re: hollow vessels
Re: hollow vessels
John Jordan
The drawing of that last bit that is unturned is really to determine the inside bottom. I will cut in with a parting tool enough to determine the outside bottom. You don't need a line to follow, just shape it to continue the line of the shape.
Dick is right-sometimes on bigger pieces I use a faceplate with the bottom shape inside the screws. In that case, I have to reverse it before finishing the shaping.
Look at the articles on my website, there are pictures in some of the articles that show this.
JJ
Re: hollow vessels
Lyle Jamieson
Re: hollow vessels
Lyle Jamieson
My methods most likely evolved from your teachings John. I should give you credit for much of the foundation elements of hollowing you provided me twenty some years ago. Thanks for that solid foundation.
Re: hollow vessels
Re: hollow vessels
John Jordan
That's kind of you Lyle, thanks!
John
