Pluses & Minuses, Positive & Negative
charlie belden
We normally think of single axis, single profile, single pieces. Sometimes we see sets of three or five of some single axis, single profile form - a set of bowls or lidded boxes. Occasionally we see sets of single axis, single profile objects that incorporate the "negative space" between the turned forms as part of the look of the whole piece.
Less often do we see multi axis pieces - and when we do - it's usually a single piece - some of Peter Rand's work being an exception - with his multiple multi axis sets.
Here's an idea I've not seen before - positive single axis single profile forms placed to create a 2D shape in the negative space between them - and then - turned on two parallel axes, each with its own profile - a positive form of the 2D negative shape.
In this example, the two outer single axis, single profile pieces create a negative space between them with a profile of a Mandarin Man. The middle three forms are two profiles turned on two parallel axes - and are 3D versions of the Mandarin Man profile of the "negative space" - which, in turn - create negative spaces between them of the original positive forms . . .
If you look at the 3D forms on both ends of this image and note that the left most form's profile is that of the front of the multi axis Mandarin Man, and the right most form's profile is that of the back of the multi axis Mandarin Man, a little mental gymnastics of overlapping these two forms and extracting their Common Volume will create the 3D multi axis Mandarin Man form.
Here's a link to a YouTube video animation of the SketchUp virtual 3D model of this idea.
https://www.youtube.com/watch?v=-lftltrGJ44&list=UU-U4g9pggKMv1rYKvKTtynw
Comments, questions and suggestions for other pieces to try are welcomed
Re: Pluses & Minuses, Positive & Negative
Charlie. Stephen hogbin explored this years Ago. I looked into it by doing inside out turning and rotating the pieces 4 times then place them together to create the negative image. I like what your doing with the multi axis.
here's an example...
GaryG in MD
of ceramic vases by Greg Payce. ...GG
Re: here's an example...
charlie belden
Perhaps a Fig Leaf is in order ; )
This is an example of going 2/3rds of the way to the idea. I wonder if it would be possible to throw two different profiles in one ceramic piece. THAT probably requires a Subtractive Process - which is what wood turning is - subtract everything that doesn't look like and elephant to turn an elephant.
Two parallel axes, each with its own profile pieces really aren't that difficult to design and turn. There are a few tips and tricks that make the layout and turning easier, which I'm working on developing the illustrations for, but it ain't rocket science.
What I find so interesting is how the profile of a multi axis piece can continually change as you change your vantage point. Add negative space between multi axis pieces and the interest level can go up a notch or two.
As an old TV ad used to say "Try it. You'll like it."
Rude's candlestick
Barbara makes a statement that Rude told here to find something simple and stick to it, I should have listened to him. Made me laugh. We should all be that lucky. My turnings get more and more complicated and of course so do Barbara's and Charlies.
