anyone need a lathe and up for a challenge
I went to a friends house to look at a lathe he picked up. Unfortunately it's not all there. It appears to be modeled after a metal lathe so the bed has V shaped risers in it to help keep things aligned. It was originally a 12" swing lathe but someone made some massive adaptors to fit under the headstock and tailstock to give it 16" swing. The headstock has a #2 morse taper but I didn't take the faceplate off (if it comes off) to see what threads it has. The tailstock has a #3 morse taper. It uses bushings or babbit bearings that must be oiled. It's very heavy, proabably 400 lbs. It's missing the banjo and tool rest although I have one that may be adapted to fit if your handy. Has a 4 step pulley and a motor that sits on an outboard adaptor.
It can be had for a song if you live nearby and want to haul it away. I would normally take it and work on it but I'm up to my ears in getting ready to move and don't need any more tools to play with. I can get a photo of it if anyone is interested.
