I need to transport my shop equipment an hour + down the highway. Any problem if I lay it down & strap the bejeezuz out of it? I'd rather lay it in a covered trailer than stand it up in a trailer or pick up truck bed (January weather in Ontario being somewhat sketchy).
My saw is a 14" "euro style, if it makes a difference.
That's how i transported my 16" mini max was on it's back. Couldn't lay it on the outboard side because of the motor and if I layed it on the inboard side it would be setting on the table. The back on this saw is relatively straight and the base was wide enough to make it reasonably stable so it took very few straps to hold it in place.
Steve, it is relatively easy to take the table off, and I certainly would, because the tilt parts are pretty easy to break or bend, plus it gets lighter, and you may find a flatter more stable side to lay on with it out of the way.
For the large ones I've moved, I'll even take the wheels off, but I'll bet you won't need to go that far.
