Source for stainless steel ferrules
Jake niedling
I have some ice cream scoops that I need to turn some handles for, but I would like to add a stainless steel ferrule. Any suggestions or sources?
Re: Source for stainless steel ferrules
Not the same, but would brass work?
You can make brass ones out of plumbing fittings "fairly" easily. Use compression fitting nuts and either turn the hex part off or leave it.
Re: Source for stainless steel ferrules  *LINK*
David Walser
Jake -- I don't have a good answer for you, only a suggestion to aide your research. Try some of the fly rod builder's supply houses. People who make custom fishing rods need the metal bits and you might be able to adapt those bits to your needs. I've included a link to one example supplier.
Good luck!
Rush River Rods
Tony Rozendaal
Hut has them for duck calls.
I recommend you call before you order online. Hut will backorder on out of stock items and ship and charge your CC when they come available.
Stainless steel bands
Rob Wallace
Rob Wallace
I suggest you try MSC (www.msc-direct.com) and search for "stainless tubing".... you may need to buy a 6 ft. section, but you would be "full of ferrules" for a long time (!). Or buy a piece, cut it up, and share the cost with other club members for making classy, stainless steel ferrules!!
For example, a 3/4" OD piece of 304 stainless tube at 6' length costs $ 53.12 (that's 74 cents per inch, plus shipping). Of course, other sizes of tubing are available. I have bought lots of 304 stainless items (pipe fittings, rod, tubing, etc.) from MSC over the years for use in my home brewery.
See: http://www.mscdirect.com/product/details/01412477
Good luck with your project!
Rob
barry rockwell
Barry Rockwell
Jake, chances are that someone you know has a metal lathe. They would be quite easy to make.
Re: I would, but the scoops are Stainless
try this *LINK*
If they won't sell them seperately look for some stainless tubing and I can cut it for you.
http://www.chefwarekits.com/woodturing-project-ferrule-4-pcs-kit-chisel-handles-and-more.html
This is what I was looking for....
jake Niedling
but they are kind of pricey at over $4 each. I think I will buy some SS tube/pipe and get some cut up. I have around 12 ice cream scoops, so will need more than a couple anyway. If i find the tube I need, i might take you up on your offer to cut them. Thanks, Jake
Thanks for the input, some good ideas.
Rtubing *LINK*
I doubt this is polished so you would have to do that but I can easily cut it up into lengths for you.
http://www.onlinemetals.com/merchant.cfm?pid=14763&step=4&showunits=inches&id=312&top_cat=1
Jake, Its $4.50 for 4, not each.....
But they are not stainless.
The tubing in the ad below is stainless, but it about a buck and inch and it 1" in diameter.
If you have any boating supply places.
Keith Newton
Lifeline stanchions are always polished SS. But maybe a place that fabricates bimini tops would be a good source. They would be producing tons of scrap of polished SS.
But then, the scrap metal yard near me will always have a mountain of SS, that I can pull whatever is around the edges out, for about $1 per pound now I think. There is probably one or two salvage yards in every major city.
With abrasive blade in a cut-off saw, you can make your own. But do try to find the best finish that you can get your hands on. While you can polish out the scratch from a lower grade, it is really a pain in the Uknow.
Re: If you have any boating supply places.
non of the salvage lots around here will let you scavenge for parts or metal. It sucks. They used to let me but someone must have passed a law or insurance may have stopped them. It's a bummer.
2nd Online Metals
Don Orr
I just got a few pieces of Brass and Stainless and they are excellent to deal with. Wide variety of sizes. I got the welded seam stainless T304 which is cheaper. Got the "random length 10-12"-very cost effective.
John Stegall
one of our club members who makes handles for the tools he sells gets SS tubing shorts from a business that installs handles for businesses that want to comply with ADA. He gives a small turned item for lengths of their scrap before it leaves for the scrap yard. I found a couple of tubes from a broken glass shower door. Maybe a glass company would have some.
Keith Newton
That is too bad John. The owner of the one here is a great supporter of the Arts, Craftsmen, and Craftswomen. Of course nobody is allowed to go climbing up onto piles of stuff to pull something out. But nobody in their right mind would want to do that anyway.
We also can't take wood out of the dump
I did go into the local dump to take a big pickup load of limps and hedge. I saw 2 beautiful Ambrosia maple logs and so I loaded them up expecting to catch hell as I tried to leave. The lady doing the weighing didn't say a thing and I know those had to weigh more than what I brought in.
Same thing with our local chip mill. We used to go up there and get wood and the guy would actually use the front end loader to put it on our trailer. Now you can't even go into the site. You can stand outside the fence and drool all you want.
