I know we have covered this several times, but I am not understanding this. I downloaded a manual camera app for my phone. I remember John an Jamie telling us to set the White Balance at +1.
The white balance on the camera app has a scale from 3000 to 8000.
The +1 we were talking about is an exposure problem based on using a white background. that is a separate issue from White balance. White balance is about the color of the lights and matching the camera to them. The 3000 to 8000 is the degrees Kelvin of the lights. you need to find out what kind of lights you have. 3200K is tungsten balance which roughly matches standard household bulbs. 5000 to about 6500 roughly matches daylight. YOu need to find out the degrees kelvin your lights are. If you don't know buy some lights that do have the color temperature listed. Some CFL bulbs do. Many standard Tungsten don't have it listed. You can try setting different temperatures and see if it produces accurate color. Shoot a photo of something with white and gray and some colors you can easily see. Set the camera to 3000 and see if the color is correct. If it's not set the camera to 5000 and see. If this isn't right try other settings. If none of them work then your best bet is to buy some bulbs that have the Kelvin temperature listed.
Thanks for the update. And for all the continued education in general. Does not appear that I will ever take quality photographs, but I will keep trying.
What phone are you using, and what is the problem that you are trying to overcome?
I personally wouldn't fool with that type of exposure changes without having a good or better understanding of the light. That being said, I hope you know that there is a lot of correction that can be done after taking a less than stellar shot. Learning to use some of those options in your computer, or even in your phone would probably be a better path for you to try.
Does your phone camera have a HDR option. I find that to be one of the easiest things to improve lousy lighting, in that the camera takes 3 quick secession images at different exposure levels, then it chooses the best part of each of those and merges them into one much better image. But it requires that when you take the shot, that you hold it pretty steady.
....question with good info, and some practice with varied color balance and exposure will help you find the correct settings to use going forward. Don't forget to make some notes about what lights and exposure settings match to give the best results to aid in future situations.
Thanks, I am keeping a record. All the setting made sense to me except the White Balance. After Johns explaination, I can add that to better understanding.
First, I want to say that the work looks great, and your shots aren't that bad. The worse thing I saw, was in the last photo, I think the backlighting may have been hitting the lens of the camera, which if it is like mine, usually needs a little cleaning due to living in my shirt pocket, which can develop a film from my perspiration condensing out onto it. If your light source hits it, that is like the camera having a case of glaucoma. That orientation may have been good for showing the shadows in the relief work, if you could have shielded it from your lens.
I think you should still post your shots, so some of the others can share their observations. I'm pretty sure there are other professional photographers here that are willing to help.
I noticed that you sent them to me from your iPad, and I'm sorry to say I have no experience editing on that device. I may see what I can do with the last pic in iPhoto in my iMac, and send it back to you. But don't be shy about posting your shots, this would be the best way to learn.
Thanks so much. I have been experimenting with the editing program. I had only used them for cropping before. I am surprised at the lighting improvement since you suggested to try.
