Wife sent me into town to pick up a few grocery's saw this wood along the side of the road. I stopped and asked if I could remove it for them. they where happy to have someone take it. The large piece is better than 3 ft across. I'll be back toma rrow to cut it into pieces to load into truck. Any ideas on cutting the large piece?
Yep Jesper, looks like I might have some good stuff to turn, sort of wish I was into HF's. went through tank and half of gas and not nearly done. I've only got 18" bar so It's been a challenge just to get it in samall enough pieces to handle.
Too late, but I would have suggested cutting horizontal across the middle of the lower picture above, with a good possibility in the middle of the top, in between.
One thing that may help, is to knock a little of the bark off with a hammer, so you can see what kind of figure lies beneath. I like to use a 20 oz framing hammer, striking at about 45º. It is easies in Spring, and hardest in Winter, but still doable.
The Arborist call this portion of a tree a "cathead". How it got that name, I don't know.
The wood is sugar maple. I prefer the 18 inch bar most of the time, its easier to maneuver, and you can cross cut a 36 inch log.
If you are cutting down into the end grain, the way it is in the picture, it will take a long time and is very hard on the chain and saw. Turn the log on its side and cut along the grain and/or cross cut it across the grain. Leave it as big as you possibly can, then keep it covered tightly and cut it as you use it.
....if you've used up a tank and a half of gas already. The tree crew probably used about that much to drop the entire tree. As John said, put it on it's side if you aren't done. But, those multi crotch pieces are plain hard to cut. Long grain, short grain, crotch grain, all those make it hard to cut. Also stay out of that black decayed spot. For some reason that I've never figured out, those tend to be very abrasive.
John you are right on, it is sugar Maple, but it is a dead stand and has already started some spalting. I ended up cutting cubes of sort most 12" to 16", luckly the homeowner was there and was able to help me lift them into the truck. I only have a 1/2 ton truck and it did make it squat down some. yes it was some tough cutting, but I think it will be worth it.
