Please tell me that it's me that is stupid - and how. I ordered a VG 2 for Christmas, assuming it would fit the track etc. I already have for the original Varigrind.
This is adjusted to the utmost pointy nose angle - about 75°, which is no use to me. There seems no way to get any better adjustment, other than to remove the guards on the grinder, and that is not going to happen. The Grinder is a Baldor slow speed, which must be considered, if not a norm, then certainly a popular one in the turning community.
This is the original on the other side of the grinder, showing that it can be further adjusted by both lengthening the sliding bar or the amount the tool sticks out and the set angle on the tool holder.
No you are not stupid, or if you are stupid I'm a lot stupider. The VG II is a nightmare to set up for a traditional swept back grind. I have been suggesting to my students for years that they NOT get the VG-II. The good thing about the VG-II (if you can get it set up for the grind you want) is the grinding action stays in the middle of the grinding wheel. For a turner with limited physical ability or something like a tremor of the hands, it is a Gods send. But most people do not need that help.
The first time I used the VG-II it took me forever, I mean a really long time to get it set up to sharpen my grind. I can set up a grinder for my grind with a VG-I in a matter of seconds, not minutes, and it took nearly an hour to make the VG-II work for me. It was a frustrating nightmare. And I have set up hundreds and hundreds if grinders over the years.
The VG-I can be confusing too. See my YouTube clip on sharpening for details. http://youtu.be/0zUph9zEjck (Sorry I don't know how to get a link to post) The sliding arm controls the grinds side angle and the jig arm adjustments control the tip angle. With this as the foundation for set up, it is complicated because when you move one the other is affected.
I do not like the Vari grind 11. I grind my main bevel and then slide the Varigrind forward in the V slot to grind a secondary bevel. You can't do that with the VG2. I also like moving the tool around on the stone to keep the stone level or on the CBN wheel to try and wear the wheel more evenly. You can't do that with the VG2.
As Lyle mentioned it's only saving grace is that you can't run the tool off the side of the stone accidentally.
Note that this technique is somewhat different from what you usually see (relating to free-hand sharpening) in that the tool being sharpened is totally hand-held. It is not placed on a tool rest of any kind. In fact, my grinder does not even have the tool rests installed. What is important, however, is a convenient place to rest the hand that applies the tool to the wheel. That's the purpose of the platforms you see in front of the wheels (in the photo in the article).
I've taught this technique to several people, some of whom were initially rather skeptical. And I'll admit that some practice is required in order to roll the bevel against the wheel smoothly. Further, some folks initially have problems coordinating two hand movements, but everyone who gave it a serious effort was successful.
Arguments against free-hand sharpening include: Lack of repeatability; excessive metal removal; getting multiple bevels and facets, etc. Forget these. After you practice a bit, none of these will apply.
And in favor of free-hand sharpening: First, you don't have to fiddle and fret with the jigs. Second, after you get a bit of experience, you can modify the grind to suit your needs or preferences . . . like grinding the tip of a bowl gouge just ever so slightly unsymmetrical to favor cutting in one direction over the other, and so forth. And free-hand sharpening takes much less time to do.
Just my opinion, of course, and I'll admit I'm a bit biased. I've never used a jig. I don't even have a jig. Nevertheless, my suggestion would be for you to give it a try. You might like it!
The Robo Rest has made it possible for me to free hand sharpen all the gouges, skews, parting tool, and scrapers on a platform for anyone interested in this approach. Changing angles takes 3 seconds and is quite repeatable and accurate. But everyone should stay with the method they prefer.
It looks like this grinder will handle larger diameter wheels. If that is possible, then it will give you the clearance you need. Just food for thought
I already sharpen parting tools and skews freehand. The freehand skews a la Eddie Castelin with a slight convex bevel, which I find easier to use - and straight off the 180 grit CBN without further honing.
I'll have a go at freehanding gouges, but it still means the VG-2 needs to go back to Oneway.
Good thinking, and it looks possible from the pictures, but is not in reality. The right hand is a full 200 mm (8 inch) CBN, and there is no inside room for any increase. The left hand blue wheel is a bit worn, maybe down to 180 mm, and I am wafling over whether to replace it with another Norton 3X or get an 80 grit CBN.
The combination of the 80 Grit blue and Thompson scrapers seem to function very well, producing durable burrs in a very short time with a simple platform jig.
The jury is still out on NRS. The few old scrapers i have ground to negative rake has not convinced me yet. I have not gone the whole Doc Green route as yet, but we will try this and compare at one of the next informal turners meetings in Copenhagen.
