Some recent stuff. Holiday and other.
Craig Daymon
This is a Sea Urchin ornament I created for my brother and his family. There is a Jatoba (Brazilian Cherry) collar on either end and then Kingwood is used for the bead on top and the finial on the bottom. (Pretty sure it's Kingwood. No purple in it, but great grain.) Top and bottom are connected with a 3/16" dowel running through the center, no glue on the shell. Wood parts sanded to 1500 and finished with Conservator's Wax. Finial probably would have ended in an onion shape, but "design changes" were required. ;-)
Here is the box I made for my mother this year. Maple Burl, Jatoba collar and lid with a Ebony ring. The box is a bit over 5 inches in diameter and about 3.5 inches tall up to the point just below the top 2 sections of the lid. Need to put a little more thought into tools to use for a box like this when working the inside. Real easy to catch a gouge. (In other words, it looks better on the outside than in, though hard to see the mistakes, which are in the deep corners.)
This one I made for me. Masur Birch box with a Kingwood handle. About 5.5 inches in diameter with a loose fitting lid.
Comments and questions welcome.
Re: Some recent stuff. Holiday and other.
love the conical box, Craig
GaryG in MD
I haven't seen or thought about one in that shape.
I like it!
What's the "shape" of the inside -- also tapered or just a cylindrical "hollow"?
Thanks, GG
Re: love the conical box, Craig
Craig Daymon
Inside mirrors the outside. Bit rough in the far corners thanks to a catch, but not easily noticed. Probably would have been easier using different angle grinds on skew chisels/negative rake scrapers. If you've ever seen Benoit Averly hollow one of his boxes, you would know how effective this can be.
I had a large burl that I turned a bowl from and attempted to get a core out using my parting tools. Worked reasonably well, but it didn't result in a very large core and I cut the angle too shalllow. This box preserved about as much as possible from that core.
The Ebony ring was challenging as it is relatively thin where it interfaces with the Jatoba handle, and it's a ring shape.
You're not going to be able to store much in it, but I was happy with the way it looks. Maybe there will be another in the future.
great idea
GaryG in MD
I've got some similar cores and never thought of turning them into boxes!
Outstanding. Thanks for the inspiration. ...GG
