looking for suggestions on turning Osage
Mike Potts
I got my hands on some osage orange today, This one is about 12" across and 6" high I have about 3 1/2 ft. of it. My thoughts are an end grain NE bowl or vase. any comment or thoughts ?
Thanks in advance
keep it safe and have a Merry Christmas
Mike
Re: looking for suggestions on turning Osage
I'd go for a bowl
That crotch might be really interesting. Keep the excess for a smaller pots or boxes.
My 2¢.
robo hippy
The butt end of the crotch, bowl for sure, but that is what I always turn. I would be very careful with the upper part. You can see the dark spot, and odds are that it is a bark inclusion, and very weak as in it could easily fly apart. I would take at least a bowl sized chunk off the top of the crotch, and check to see how far down in that goes. You would have 2 round bowl blanks, and the pretty part of the crotch should be below that. I had an old timer tell me once that trees from the woods don't have crotch flame, while trees out in the open do. The woods trees are more protected and don't need to develop the interwoven figure. I got a black walnut once, 20 inch diameter branches coming into a 30 inch trunk. It was in a valley with lots of tall fir trees around it. No crotch figure in it at all. The bark in the Osage is pretty thick, and doesn't show crotch figure as well as thinner barked trees.
robo hippy
Don in Central Illinois
Turn it green. It is hard as iron when dry.
Dick Coers
With the look of that crotch, I would do two spherical hollow forms from that end, then go to a bigger bowl the further it gets into the piece.
I dry it and turn boxes. It threads great. I don't usually turn bowls from it because what I have always has some minor cracks so I end up turning smaller things.
walta
Whenever I have tried to show the flame figure from the crotch in a bowl the results have been a disappointment. So now I see platters when I look at crotches.
The flat surface of a platter is a great stage to display a flame figure.
Walta
George Taylor
Use it all
George Taylor
NE bowls are a great start, but save the scraps ... they make great wine stoppers, pens, bud vases etc ... (hint) apply yellow dye before you finish and may prolong the yellow color before it turns a brown (which isn't that bad either). Love the wood.
steve worcester
Turns well either wet or dry. Dry it is very hard, but has good flexibility (a favored wood for longbows).
The pretty bright yellow color, which will color you entire shop, will turn to a dull brown, worse transition than Padauk.
Some people don't like to burn it because it burns very hot and a lot of popping and sparking. One of my favorite fire woods.
Thanks for the input, from all
Mike Potts
As always a lot of good input, gives me a lot to think about. no hollow forms, still haven't got that far in my turnings. hope to go there after my trip to Pittsburgh in june. I haven't been saving the cut offs, as with my bad left hand I don't think I will ever be getting into the smaller stuff, but I hope to join a club one of these days and it would be nice to share the cut offs with members that do wine stopper and such. I guess i'll start putting them aside instead of in the wood burner.
Thanks again to all.
keep it safe
have a great holiday season
Mike
Brad Vietje
Bowls and Hollow Forms ?
Brad Vietje
I would probably make a pair of hollow forms with small openings facing the center of the crotch, and bowls with the rest. If you get any decent crotch figure, it would lie across the top of each HF, which would show well if the openings were small and the forms were relatively broad toward the top.. Yes, these would have the pith running right through them, but if turned green and thin, you could get some really interesting results.
if you're not a HF sorta guy, it looks like you could make at least 2 larger bowls (maybe 4) and at least 4 small bowls in the branched end.
Please be sure to show us what you do make, curious minds want to know!
safe spinning,
Brad Vietje
Newbury, VT
Re: Bowls and Hollow Forms ?
Mike Potts
Thanks Brad, at this point HF's are not in my arsenal but planing on trying it next year. I guess I'm still leaning toward an end grain NE, it will depend a lot on what it looks like when make my cut down about 7"down. If the crotch doesn't offer good solid wood at that point, I'll be looking at something different. Here a some pics of a NE end grain I turned a couple weeks ago. My intent was to make a shallow bowl but I was losing all the flame from the box elder and had enough excess wood to turn it into a Pedestal bowl. I'm thinking the way the branches are close to same size I could have some dramatic wings on a shallow bowl.
no finish on this bowl yet, letting do a slow dry and hope for no cracks in the pedestal.
I'll be sure to post what ever I eventually come up with. Won't be turning again till after the first of the year.
keep it safe
Mike
Love the shape of that pedestal bowl, and I'm intrigued by that natural edge bowl in the background. What wood is that?
Nice work.
Mike Potts
Ellis, that is Maple, one of my first using crotch wood, it has some very nice figuring in the bottom. Have a merry Christmas, and thanks for developing and maintaining this site
keep it safe
Mike
Jerry Hall
I made a series of small, "bailed" urns. Here is one. I liked revealing some bark or flesh. If it cracks, which it might, the texture and look of the wood is very forgiving to the look of instant coffee fillings.
Mike Potts
nice Jerry, once I get into HF's something like that will be a challenge to turn
keep it safe
Mike
