REAL MILK PAINT
Not Woodturning with Hunter tools
Steven Antonucci
steven antonucci
While not officially sponsored by anyone, I am friends with Mike Hunter (for anyone requiring the disclosure) and Mike did give me this tool to solicit feedback. I think I could use it with good results to turn wood, but I do not, as I have developed the requisite skills with conventional tools.
However, upon occasion, circumstances present themselves that make having one of these very, very attractive. One such circumstance is turning brass rod down in diameter. While it is possible to turn brass with conventional woodturning tools, the Hunter cutters are infinitely superior at accomplishing the same task. (well, duh... they are metal cutting bits after all!)
If you look at the brass rod in the drill chuck pictured, it is nearly mirror finished because the bevel of the cutter is so highly polished. Once things were moving, I was making 10' long tinsel strands on a 2" long x 1/4" thick rod...that's a lot of revolutions!
So, if you ever need to turn brass, grab your Hunter!
Steve
Re: Not Woodturning with Hunter tools
mjonesrdg
Thanks for the post! I have turned aluminum on my wood lathe, and I expect that the Hunter cutters would excel here as well.
