Shellac
Geoff Whaling
I use a lot of New Guinea Rosewood which is a very close relative of Padauk. I particularly like the deep orange & some of the purple variants if I can get it for my linear lamination work. It gets laminated up with white or near white veneers that are only 0.6 mm thick at times so bleeding of the oils in the NGR is a problem. The deep orange is always problematic and definitely has more "aromatics" in it than the other "browns" you get with NGR.
The advice on applying a sealer either shellac or nitro cellulose sealer is good. Shellac is less problematic than a NC sanding sealer to prevent the solvents from dissolving and transporting / bleeding the oils into the whites. Spraying is better than wiping or brushing.
I concentrate on obtaining an excellent off the tool finish on these pieces to absolutely minimize sanding.
ps filling open grain with the old french polishing trick of using talc is also helpful. The outcome is never guaranteed though and the configuration of the grain has a huge bearing on the outcome.
