We've had a few hours here and there above freezing, so I have made a few more tree ornaments to try out different markers, etc... This one is only so-so as far as the turning goes, but check out these growth rings:
and here the not-so-clean-cut base:
There are 61 dark bends, so 62 seasons of growth represented here, and the diameter is only 2-1/8 inch. That's a really slow growing tree!
This is a chunk taken out of one corner of a 6 x 8 Eastern or Canada Hemlock (Tsuga canadensis) post cut back about 1850. Must have been crowded by a number of other trees to grow so slowly. Would be cool to try to match these growth rings up to some database to match specific rings with dates.
Innermost radius is around 4.5", so the outer diameter of the tree had to be at least 14", and I'll bet these were mostly 20 - 36" in diameter when felled, so we could be looking at wood that was laid down at least 300 - 400 years ago, and possibly longer. Pretty cool to think about the history recorded in trees.
Given any thought to hollowing the tree to make it lighter?
I have some old growth heart pine that came out of beams reclaimed out of old industrial buildings. Probably timber cut for the buildings built for the industrial revolution. Some of it has growth rings approaching sixty to the inch. Incredable.
I have heard that out west many houses were built of fir with similarly tight growth rings. Four by fours were stood on a rock as a base under the house. The close growth rings were so tight termites couldn't get between them and tended to leave the posts alone.
Agreed -- a dendrochronologist would be a good find; maybe someone here knows a lot about this who could help out. I read a bit about the process today, and a lot depends on finding a live edge piece and preparing a slice that shows the rings from that cambium layer down toward -- or to -- the pith of the tree. Since these were cut from old growth trees about 165 years ago, the average size tree could be pretty big, and it would be unlikely we could count all the way back to the pith.
What I hope I can find is a bark edge and then establish a growth pattern that would reflect rainfall, temperature and other local conditions for maybe 100 - 200 years, and then see if other pieces would match up and extend the timeline a little further.
About 10 years ago I was given a 2-1/2" thick Am. Chestnut plank from a sub-floor of a house built in 1755. Given the radius of the growth rings, and the average size of roughly 3' - 4' in diameter of the Chestnut trees cut at that time, I figured I was turning wood that was live about 1475 or so. That's just a hackneyed amateur SWAG, but a lot of fun, and probably a reasonable estimate.
I thought about hollowing these little trees, but that would make them a lot more involved. Since my lathe is out in a cold barn, I don't want to spend the time on them, but it would be a fun project when I get a heated space for turning. They only take about 10 - 12 minutes each as is, so I figured it might not be worth all the extra time.
I met Dave back in the mid eighties, then sometime thereafter found a really old cedar tree, which I turned a vessel out of, that had ~500 annual rings. I contacted him and offered him a piece of it, hoping to find out something about it. He assured me that I must have counted wrong, because a novice couldn't possibly find the oldest cedar in Arkansas, since he, a professional had been searching for it for years, without finding anything over 350. As it turned out, I was right, and George Imrie, one of his students used my sample and location for his Master's thesis. 350 was his oldest find, besides my piece in his studies.
He shared a lot of his indices back then, and I've tried staying in touch with him every now and then since then. This has been a very interesting subject for me ever since then, and has changed the way I see the wood that I find, and made it a lot more interesting. The more I learn, the better I've become at reading the interesting features in the wood that I collect and turn.
Besides the size of the rings, there are lots of other indicators of extreme weather, such as lightning strikes and ring shake. I've got a 5' diameter Elm that I'm working on at the present, which grew about 5 blocks up the street form my shop, that I'm needing to clean up a cross section for dating the rings. It has quite a few lightning strikes that I'd like to date, and compare to some other pieces that I've worked from the neighborhood. And since I've lived at this location for 34 years, have a pretty fair knowledge of weather events, from over 60 days straight of temperature over 100º, and a tornado which passed between my shop, and this tree on Jan 21 1999.
I'm here to tell you, that when you hear a storm approaching, which has upward of 5-10 lightning strikes per second, you need to either take shelter, or get the heck out of the way. Of course, a tree can do neither, and I would bet anything this tree will bear some scars from that day.
As for the value of what you can learn from your wood, it doesn't appear to me to have enough variation of ring size to have a very strong finger-print. Dendrochronology needs many samples from an area to have any meaning after they are averaged out. An individual tree could have a sudden burst of vigorous growth from loosing a large neighbor which has been shading it from the Sun. Even a vine can have a big effect on a single tree.
I recently sent some pics from a 28" bowl to Ellis to see if he thought there would be any interest in an article about reading the rings and other blemishes, but he didn't think there would be much calling for this type of info, since it would not have any connection related to advertisements of tools. I may try to put something together to share here though. For those of you that are using local wood that you harvest yourselves, may find it fun to use some of the info to share with your customers. When you can put your finger on a ring, and tell someone that this line right here was due to a storm at the end of the drought of 1954, when the rains finally fell after two months of 100º+ temperature from June 15th to Aug 15th. A huge updraft of hot moist air has a lot of energy to release.
