Drilling through PM3520 tail stock: possible?
Aage Rendalen
I have two different size lamp augers, but none fits through my PM live center. Do I need to get the Oneway live center?
Aage Rendalen
Re: Drilling through PM3520 tail stock: possible?
Chuck Engstrom
Hi Aage -- the Oneway will accommodate up to 5/16", the tailstock itself will pass 3/8". I have a little #2MT thingy that holds -- or passes -- 3/8" which I use with my 3/8" lamp auger, which I grip outboard of the tailstock with a drill chuck.
Despite taking all care I can think of, I've never had much luck getting a straight hole with a lamp auger or more ordinary drills.
Good luck with it -- Chuck
Aage Rendalen
Thanks, Chuck. I'm only going to drill a vessel neck (trying out a two-spouted vessel based on a demo hand-out from our Richmond vizard, Tom Crabb, who now has retired from turning.)
I use a Nova Live center. Can't drill through my Powermatic live center. I also have one of the dead centers that is used with the lamp augers but i install it in my Nova live center since it is a short #2 morse taper just like the Nova inserts.
If you have reverse you may be able to bore through the headstock. I drill through my headstock using a 4 jaw chuck but you will have to grip what your turning.
Jorge
I've done lamps using a nova tailstock, Istart with a regular short drill bit, and make a starter hole, as deep as you can, flip the work and do a starter hole on the other end, now using the lamp auger, drill half way from both ends, small misalignment may be there but you have a useful bore.
Ron Bauer
I have used a gun drill for years to bore deep holes. Find them on ebay in whatever caliber (aka diameter) and length you want. Mine is 36" long. They are bored with two small holes the entire length to take a cutting fluid. They are nice because I just hold a rubber tipped fitting from the air compressor to the flushing hole and the cuttings are ejected down the flute of the drill. They are carbide tipped. With the right speed and feed (hand fed) they drill real straight. Ron.
I have probably made 20 or more lamps in the 16 to 18" range I played with several different methods of drilling. So far I have not found a way to drill all the way through from one end with out being off just a little. So I either drill the holes a d then mount the blank centered on these holes or drill starter holes from both ends like Joege said and then connect them using longer bits.
You can't get lamp rod through these holes so I glue shorter pieces into each end. This works quite well but can make it hard to get the lamp cord through. To get around this I tie a string to the cord. Then I suck the string through with my shop vac. If I put tape around the joint where the string is joined to the cord I can usually wiggle it through
bernie feinerman
Is the two spout vessel similar to an "American Indian wedding vessel"?
Bernie
extra long drill bits
David Staeheli
I too have not found lamp augur bits to drill all that straight. I make rolling handle rolling pins and have to drill 13". I've been off as much as 1/2" coming out the other end. Had some luck just buying extra long drill bits from Associated Industrial Distributors (Buydrillbits.com). Unfortuanately, my best design has to have an 11/32" hole so the 5/16" handle rod rolls freely. AID doesn't carry an 18" drill bit in that size. Persistance pays off and I did find one on ebay finally. Nice american made one. Still may be off a small bit, but far better than trying to drill from both directions.
many years ago I tried to drill a lamp after it was turned. Drilled right out the side. Since then I have made many things by gluing up a blank with a slot up the center. I glue a small plug in the slot and mount it centered it on that and when its finished, I drill the plug out.
Another thought would be to drill the blank first, before turning it, and then mounting it on the holes. This would assure the holes are centered.
Yes, it's the south-western Indian double spout
