Want to make a lame *LINK*
HeatherAinAK
No, I don't want to make something lame, I can do that without help. I want to make a lame. A little holder for a razor blade to cut a slit in bread. My husband saw one in a King Arthur flour catalog and thought it was neat. Any ideas how to make one (turned if possible) I would love to make one with a cover.
Thanks,
Heather
King Arthur Flour walnut lame
Re: Want to make a lame *LINK*
Dick Coers
The size of those brass nuts bother me, I'd use smaller. I'd start by turning a tenon on one end, this lets you use a cup center and not split open the slot. bandsaw a slot in that end while the rest of the piece is still square. Use a cup live center on the tenon end with the bandsaw slot, and turn the rest. I would use a high quality utility knife blade. Maybe an off center change if you wanted an oval handle.
I wouldn't think you would have to change the blade all that often so I would use a counter sunk brass hex nut and and counter sunk brass screw on the other side. You would have to use a screw driver to change the blade but it wouldn't be all that often.
I would just carve the handle. You can rough it out on the bandsaw and then use course sandpaper glued to a stick to round over and finish shaping the handle.
Ken Vaughan
Ken Vaughan
The good news is that a Lame is used for the specific use of cutting the shallow slashes in the top of a loaf of bread -- and the blade is a razor blade. Single edge variety is good, and I have used some that come in spring loaded handles.
The trick is to protect the blade (and the hands) - Think of a sheath - cover- case -- I do not want a lose razor blade stored in the drawer...... I like this one as the blade can easily be removed and inserted as needed. Most of us do not make bread that needs to be slashed all that often.
The brass nuts are similar to the ones used to make spokeshaves and serve only to clamp the blade in place.
I like the knobs because it is easy to remove the blade for storage.
Knobs and screws like that are available at hardware stores or at Lee Valley.
you could make it a folder
so the handle folds over the blade and protects it and you.
I was lame
I foolishly decided to install my hardwood flooring myself. Kneeling down and having to stand back up a million times left me limping for a week. Probably won't do that again unless Alzhiemers sets in and I forget how much that hurt.
Random thoughts
Doc Green
First of all, I would consider using a single-edge razor blade instead of a double. A single-edge fits the kerf made by my bandsaw almost perfectly. At the same time, the kerf is way too wide for a single.
Here is a procedure that is rather involved but which I think holds promise for an end result that looks neat and professional. First, split your blank down the middle. Then glue it back together with a sheet of paper sandwiched in the joint. Use wood glue and apply the glue to both sides of the paper. Let the glue cure thoroughly.
Turn the handle/holder to the shape you want. Then use a sharp knife or chisel applied to the glue line on the end of the blank to split it apart. Sand the glue surface as necessary to remove the paper and create a good glue surface (for gluing it back together a bit later).
Where the razor blade is to go, use a sanding block to sand away enough wood from each side to provide for the thickness of the razor blade. A double-edge blade will work fine in this case. Test the fit as you go, etc., etc.
Before committing to two screws, I would try it with one at the very end. For the screw, I would use a single #6 flat head wood screw countersunk into one side of the holder and screwed into the opposite side. You might have to shorten the screw by grinding off part of the tip -after- you have screwed it in part way to start the threads.
Clamp the two sides of the holder together and test the screw to be sure that the single screw will clamp the blade securely.
When all is in order, glue the two sides of the holder back together -with the screw (but no blade) in place. After the glue cures, do whatever carving, sanding, etc. you desire and apply a finish. Then, insert the blade and go bake some bread!
For storage, my first thought is to turn a base that will hold the lame vertical and place it in a handy corner of a cabinet rather than have it rattle around in a drawer.
A detail on splitting the blank: if you have a table saw, you will probably get a better surface from it as opposed to using a band saw. This, of course, assumes you are starting with a square or rectangular blank so you can make the cut safely. In any case, the surfaces obtained from the saw can be cleaned up by sanding.
Hope you get an idea or two from all this. Have fun! ~Doc
Steven Antonucci
Cut the slot with an x-acto razor saw
HeatherAinAK
So many great ideas! I hope this doesn't turn out like my present a while back for my daughter. She wanted an American Girl canopy and I thought the $150 was ridiculous so I made one with turned posts, chip carved her initial in the headboard and made all the linens and canopy. Turned out $150 would have been a bargain! But I hope she will cherish it. This project isn't nearly that complicated. I will take some pics if it turns out.
My husband is a wonderful cook. He gets kitchen gadgets for Christmas and I (hopefully) get CBN grinding wheels. Go figure.
Heather
Steve Worcester.
The lames I have used have been very light weight by comparison
http://www.surlatable.com/product/PRO-23857/Matfer+Lame
While I don't see the extra weight of the wood being a deficite, it does seem overkill
Almost better to make a Harry potter wand with a razor blade through it to give it more dexterity than a thick wood lame.
And for the record, I had no idea what they were called even though you told us.
Ha ha . . . Made a Lama!
Doc Green
Actually I made a lame, but it's pronounced like the first part of Lama. (lahm)
Here it is in the base which holds it upright for convenient storage in the corner of a cabinet.
I followed the procedure I outlined above. A single #6 screw 5/8" long secures the blade.
After turning the handle, splitting it apart, and sanding the two glue surfaces, I carved a shallow recess in each half to accommodate the thicker portion of the single-edge blade. If you loosen the screw, the blade can be changed easily.
I found that part of the flattened glue surface in the vicinity of the blade must be sanded away in order to allow the sides to flex and be pulled against the blade. Also, when gluing the two halves back together, do not apply glue closer to the blade than about 3/4".
Overall length is about 6". The diameter of the handle near the blade is a tad over 5/8". The smallest part of the handle is about 3/8".
The base is about 2" in diameter and about 2.75" tall. A 1" hole is drilled to a depth of 2" to accommodate the lame.
Fun, fun, fun! ~Doc
Steven Antonucci
Big Brother is watching
steven antonucci
Just looking at my FaceBook page, and the right side is where they run banner ads...
What do you think I saw? A King Arthur lame for $29.95...
I'm going to go make a tinfoil hat now...
Steve
Re: Big Brother is watching
John Altberg
Me too, Steve! Sur la Table showed up as well. Can I get some of that foil!?
Re: Random thoughts
Hugh Buttrum
I took a bread making class in SF many years ago. The instructor had the "lame" to use the first weekend. I saw it and said ......I can make one of those. I went home and cut up an old bandsaw blade and ground the one end to fit inside the double edge razor blade. I actually made a bunch and gave them away in the class the next weekend. I just used the ground down bandsaw blade for the handle......a turned wood one would be much nicer.
Now I make no knead bread and let the top just break the way it wants to. Make it about twice a week as the bread does not keep too long.
Hugh
Re: Random thoughts
Rum
I've just been using an x-acto knife.
The thinner razor blade would get a nicer cut I think and a nice wooden one would certainly be prettier!
Thinking about a flip over blade guard and some sort of cam lock design because I love overcomplicating things (not that this has a hope of getting up the project list anytime soon unless I get tired of something else and want a break).
