REAL MILK PAINT
Small motor problem
Small motor problem
Small motor problem
Chuck Engstrom
Hi folks -- I have a 1/4 hp split-phase 120v Dayton motor, model 5K977, mounted to spin an MDF wheel for honing turning and carving tools. When I bought it at a yard sale some years back, it appeared to be new, clean, and unused in original box, though it's clearly got some age on it -- label says Dayton Electric, Chicago 48, USA, so it's pre-Zipcode era. (Dayton motors now seem to be manufactured offshore.)
It worked just fine till today. It now hums when I turn the switch on and doesn't always start, and if it does, rotation isn't always the same. If I give the shaft a twist, it will start and run in the direction I've twisted, CW or CCW. I can hear the centrifugal switch click on and off OK. Behavior is entirely the same if I detach the belt that drive the MDF wheel. Shaft seems to turn freely by hand when it's not running.
For the relatively short time periods I want it on for honing, I could be content to give it a twist to jump-start it in the proper direction, but of course I do wonder what the problem is. Does anyone have any suggestions on what it might be?
Thanks very much -- Chuck
Re: Small motor problem
Don McLeod
I don't know the motor but from your description of the problem, I believe you've already diagnosed it. I would pull the plug, remove the back case where the centrifugal switch is, clean the contacts, lightly oil the bearing, put it back together, plug it back in and see if the problem has been rectified.
That's a classic symptom of a bad start capacitor
Tom Stevenson
It sounds like a starting capacitor. But, the same thing happened to one of my motors and it turned out to be dirty contacts. The Brake was clicking on but the contacts were not allowing the capacitor to be reconnected into the circuit. Cleaned the contacts and it is working great. Some times it is difficult to find a replacement capacitor. So try the easy solution first. Good Luck...
Phillip Medghalchi
2nd that. We both had same problem.
Possibility: no start capacitor
Doc Green
Given the age of the motor, there is a possibility that it may not have a start capacitor. In that case, the centrifugal switch is very likely the culprit, as has been stated above. The worst case would be for the start winding to be open, but I think that is unlikely.
I have a 1985 vintage radial arm saw that uses a capacitor and centrifugal switch, and about once a year, I have to clean the contacts on the switch. If the switch doesn't make contact, the motor will sit there and hum rather loudly but give no indication of beginning to turn.
Good Luck! ~Doc
If it is a split-phase motor
Bill Howatt
Split-phase motors do not have capacitors. They do have a centrifugal switch and a start winding though. The start winding's characteristic gives enough of a phase shift without a capacitor to start the motor.
I'd check out the centrifugal switch first. Only other thing really is an open winding or bad connections.
Bill
Don McLeod
The internet is your friend.
I see that Grainger (www.grainger.com) carries that motor (also available on Ebay), however it is no longer made in the USA and is now made in China.
If parts are needed to make repairs, they should be available at any electric motor repair shop.
Chuck Engstrom
Hi folks -- many thanks for the suggestions. It does not seem to have a start capacitor. I opened it up and cleaned everything as suggested, but when I had it back together it popped the breaker, so I must have messed something up. Back to the drawing board.....
--Chuck
