Gadgets, tips, tricks in the shop
Phillip Medghalchi
I like to start this thread about gadgets and any tips or tricks that you can think of you created or used around the shop to save you money or helped in getting a task done.
Things that are not usual or sold in the store for turning purpose.
Like the example bellow, things that you have up-cycled to help the environment.
I recently came up with this idea that helps avoiding to use the nitrile gloves once and then throwing it away.
Well, with the new ideas of packaging you noticed that they use these balloon wraps which look like a hoagies made of plastic with air in them, So for a long time we were putting them in the plastic recycling bin and there they went.
I figured that if you use a scissors and cut one side of it along the top and deflate it, it can then be used with putting your fingers in it to hold your bowls while applying finish, or specially when you need to apply CA glue. then you toss it and cost you nothing because you already paid for it in your purchase.
Now, I like to ask you add to this thread if you are doing something like this to help the environment and also our bottom line. hoping that this thread will get large enough that Ellis will add it to the library. I will add to this later as I come across them.
Thanks for helping.
Re: Gadgets, tips, tricks in the shop
Nitrile Gloves
klowwn
I'm a cheap SOB so I don't use my nitrile gloves just once and throw them away. I learned this trick from the mechanics at the auto shop where I used to be a serve writer. Before taking them off I wipe my hands dry on a paper towel. As tight as they are - when I taken them off the glove fingers tend to fold back in as I pull my fingers out. I then blow into the glove to finish popping the fingers so the are now inside out. The finish or what ever was on my glove in now inside. Next time I go to use them they are usually dry and I just put them on as they are with the old finish on the inside. and the original inside surface of the fingers is now on the outside making a fresh surface. I can usually reuse them this way 2-4 times before a finger tears or they are toad to use. the only time I can't reuse them is if I get CA glue on them and don't wipe it all off before removing the glove and the CA glue ends up inside and glues the glove finger shut.
By the way -
klowwn
I forgot to mention that I do use your idea and have been reusing those shipping balloons for a quite a while since Amazon sends them a lot in their packages and I tend to order a lot from Amazon. Keeps the nitrile gloves cleaner when using CA glue:):)
Re: By the way -
I use mine over. I pull them off which turns them inside out. Whatever is on them usually dries. When I need them again I start turning them inside out and then blow into them which inflates the fingers to get them turned. I do buy the powdered gloves which makes it possible to get your hands back in.
Mike Stafford
I do the same thing with my underwear...
Clarification Please
You inflate?
You reuse?
You powder?
All of the above?
:D
Re: I do the same thing with my underwear...
Ron Pemberton
Silk or cotton? Brief or boxer?
Roy
After your Grateful Dead tee-shirt finally gets too many holes to wear, you can recycle it into shop rags.
Roy
Ric Taylor
Ric Taylor
I've been wearing my favorite tshirt for many years, I finally have it broken in the way I like it. The odor of Pledge does bother me, but only for a few minutes.
my Grateful Dead t-shirt will never
Rum
get to many holes to wear!
Dale Miner
Whatever is on the inside is usually dry by now..... EEEEYOUUUUU.....
Phillip Medghalchi
Really Mike, is that how you answer to John's reply. Now we know why your work looks............!
Mike Stafford
Be nice Kami, be nice...
Phillip Medghalchi
Next one is gluing a cheap magnet to your pen/marker/pencil and stick it to your lathe so you do not have to look for it in the saw dust. (not originally my idea)
Phillip Medghalchi
When yo go to the fast food restaurant or taco places. save those small condiment cups and use them around the shop for mixing epoxy/glue in small batches.
When you buy Gello, or yogurt, those cups can be used to do casting for bottle stoppers.
Phillip Medghalchi
Jam/preserve jars with the rubbery seal in the cap are good to keep small amount of finishes in them. :D
The best thing I ever did was to buy a box of Dixie cups and a bag of craft sticks from hobby lobby. I always have them to mix anything that needs mixing. Paint, epoxy, stains or whatever.
I use to use them until I knocked one off and broke it. What a mess. I now use the plastic peanut butter jars. I eat a lot of grilled peanut butter sandwiches so I always have plenty
Re: plastic cups
Rum
I bought three 100 packs (at least 100 packs, might have been bigger) in different sizes at the local commercial food service place ("cash and carry" also known as "smart and final" - available on the left coast, not sure whats in the east side of the country). I can use the little 1oz ones for measuring epoxy and other similar things and the bigger ones for mixing stuff in.
Cheaper than hobby lobby (which I don't have locally anyway).
Re: Be nice Kami, be nice...
Phillip Medghalchi
Mike what the heck is this you keep calling me? What is Kami?
Phillip Medghalchi
John, I do that too, but somewhere I read that the glass is better for the finishes, because you never know the stuff in the plastic and the finish carriers will react to each other. Of course I had the same mess happened to me.
