Eccentric chucks
Gary clarke
Anyone have experience with eccentric chucks? Pros and cons? Thanks
Eccentric chucks
Gary clarke
Re: Eccentric chucks
Ralph Lindberg
Which ones?
I have the Sorby insert that goes into a #2/2-inch/50mm jaws, this allows off-axis turning. Within it's limits its great. Since it's adjustable you have to finish at each setting before going on, you can't reset to an old setting.
I also have the off-set axis system from Penn State. For pens, bottle-stoppers, small-boxes it's fine. It has some of the usual Penn State quality issues. But it is smack on worth the money
I have the Vicmarc VOD (oval turning), I understand it's gotten more expensive since I bought it. For what it is supposed to do, it can't be beat.
I've played with a friends Vicmarc Escoulen Eccentric and really want to get one, when I can afford it.
Donna Banfield
In addition to Ralph's comments, both the Vicmarc VOD and Escoulen chucks can only be used on full-sized lathes. The lathes need a lot of mass weight to help balance the eccentric revolutions of whatever you are turning. In fact Escoulen's chucks are only available with thread inserts to fit the larger spindle sizes, to restrict their use to bigger lathes (i.e., no Jet minis).
