Christmas Tree Ornament YouTube Video Posted *LINK*
Brad Vietje
Brad Vietje
I still have a whole lot to learn about video production, but I posted a video showing how to make a simple Christmas tree-shaped ornament in response to a challenge from on-line turners Carl Jacobson & Alan Stratton. a little long, but I tried to leave in the instructional parts to help beginners.
Video is here: https://www.youtube.com/watch?v=S1bpAMEglWY
Since I've wanted to learn how to make turning videos anyway, this has prompted me to try to learn what I could on a deadline. A little tough, since the temperatures have varied from 9*F to 59* to -3* to up into the 40's today... all in less than a week ! (?). When the temp's warmed some 50 degrees in about 24 hours, everything in the barn was wet with condensation, even the wooden handles of the turning tools. I really have to get my (heated) shop space finished!
Safe spinning,
Brad Vietje
Newbury, VT
Re: Christmas Tree Ornament YouTube Video Posted *LINK*
Peter Lamb
Well done. Thank you for your effort.
Brad I'm turning ornaments today. Our club is a little behind on decorating a tree so we are all going to make a few more. The tree's look like a lot of fun so I will make a few to see how much fun they are. Thanks for posting. By the way it's going to be 67 here today. Hate to rub it in, but I will. :)
Brad Vietje
Brad Vietje
67 is good for turning! We're having yo-yo temp's this week.
I've made these a little narrower with 2x4's ripped on the band saw, but some softwoods are pretty lousy turning woods. For beginners, I think crappy dimensional lumber makes great practice wood; if you can get nice, smooth cuts on a piece of Douglas Fir or Balsam Fir, you'll get great results with better wood.
My favorites for these little trees are the softer, lighter hardwoods: Boxelder, Basswood, Soft Maple(s) (red- , Silver-, Big Leaf-, etc...), Willow, and Poplar (Aspen, Cottonwood, etc...)
Another variation would be to spray paint the basic tree shape then cut through the paint.... haven't done that yet. Might be good for darker colored woods, too.
Safe spinning,
Brad Vietje
Newbury, VT
Don in Central Illinois
Excellent video. Will have try this tomorrow..
A suggestion when using softer woods
I didn't try it today, maybe later in the week. I found my markers tended to bleed into the end grain of the cut so the edges of the cut don't look as clean as I would like since color goes fairly deep. I made several passes with the skew trying to clean up the color.
What I do when I put colored epoxy into grooves is to paint the groove with thinned lacquer. This seals the end grain and keeps the dye, pens, or paint from wicking into the end grain.
If I have time maybe Tuesday, I'll try another tree and brush lacquer into the off center cuts. The color the grooves. Then make a skew pass to clean up the edges and take off the brushed on lacquer. This should leave cleaner edges on the colors.
I made a couple of harder wood trees and the bleed was reduced considerably. Still I think it would only take a second to apply the lacquer and dry it before coloring the grooves.
Brad Vietje
Re: A suggestion when using softer woods
Brad Vietje
My colored markers are getting a little old and weak, so mine didn't bleed too much. I think inks would run a lot, but thicker paints or gesso might work fine -- even tempera paints or milk paint. Since they are in spindle orientation, the bleeding would tend to be along the length, and perhaps not spread through the side grain (?)
Another idea would be to spray paint the outer profile, then cut through the pigment to reveal the wood beneath. With darker woods, this could be silver, gold, or copper metallic paint, or maybe even white. I haven't done that yet, but I'd like to -- just too few warm (30 degree plus) days this time of year.
I suppose another twist would be to cut the grooves, paint 'em, and then clean up the surface with the skew, cutting away the painted surface and leaving the painted grooves... fun to explore. These little fellas (or are they female?) are fun to make, and most of us could make a few dozen in a good evening.
Safe spinning,
Brad Vietje
Newbury, VT
A fairly thick body paint or Gesso would also cover up some of the grain tearout you get on less than good quality wood. It's really hard to cut the V grooves and not get tearout on these woods.
As you suggested in your first recommendation woods like Maple, poplar and other quality woods will cut clean enough this may not be a problem.
Another option is to turn it to completion, paint the slots, then use an Ink brayer to paint the Tree. Of course part of the fun of these is having the wood show and that would cover it up.
Ernie Miller Topeka
Thanks looks fun I will have to give it a try.
Jesper, Denmark
Jesper, Denmark
Brad,
You can stop apologizing for your video production.
Excellent presentation and cute little ornament.
that's a nice project
GaryG in MD
Well done in all respects. ...GG
Bill Blasic
Re: that's a nice project
Bill Blasic
Brad, Very nicely done!
Mike Stafford
Mike Stafford
Brad, I love these ornaments. I made a bunch of them a few years ago when someone in our turning club gave a demo and provided a handout.
I made mine in two pieces to that I could hollow the tree through a small hole to reduce some of the weight. Then I glued the "trunk" back into the hole.
Very cute shape on yours.
how about a 2 axis turning on the tree
Turn the tree top portion on 2 axis so the top would lean a little. then do 3 axis on the bottom half and 3 axis on the top half. This could really be a fun project. I'm getting ready to add some puff paint to some of the ones I turned yesterday to add a little more decoration. Photo coming later.
Brad Vietje
Re: how about a 2 axis turning on the tree
Brad Vietje
Perfect! The whole idea is to share basic concepts, and let people run with them. If I had more shop time (barn time?), I could try a number of variations, so I'm really glad others are doing the experimenting and reporting back.
In my new (imaginary?) shop, I'd like to have an area set aside for coloring, texturing, carving, burning, and all these great enhancements I see on-line. I spent an afternoon with Mike Hosaluk about 10 years ago, and I am still knocking around ideas for surface enhancements -- that guy is pretty incredible.
Safe spinning,
Brad Vietje
Newbury, VT
trees with puff paint
Brad You can see the problem in the tree on the left with the wicking of the ink in the pens. I think your idea of paint is a better option. I'll try that tomorrow or wednesday.
Brad Vietje
Brad Vietje
Thanks, Jesper! I surely need to work on the transitions -- I keep clipping off the last word, but I'm learning how to use MS Movie Maker, with a lot left to learn. I've done lots of teaching and demonstrating, so the turning part is easier than trying to edit videos.
This was my first attempt at anything beyond standing in front of the running camera. Since I've wanted to make some instructional turning videos "someday", the challenge to turn a square block to a cylinder nudged me over the edge to at least try it with the equipment I have on hand. Sure is fun -- more to come, if all goes well.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Brad Vietje
Hey Mike,
I thought about parting the blank at the widest part of the tree, hollowing the cone, then gluing the bottom of the tree, trunk, & base back on there for finish turning. Seems that would be easier than hollowing through a hole. Now, thinking that through, it might work best to hollow the tree section first, glue it back together, and then reduce the diameter at the top of the tree and do the eccentric part, so there would be a good strong area for chucking during the hollowing.
Fun little project with many variations.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Brad Vietje
I edited out the discussion of wood selection for the ornament challenge submission -- may have left it in the intro section that I posted first (?)
Many softwoods -- especially the fast-grown crap they use for 2x4's these days -- have such a difference between late and early annual growth that the lines tend to be much harder than the light colored wood between them. Spruce, Fir, Hemlock and to a lesser degree, White Pine are just not good turning woods compared to most of the fine grained hardwoods (except in the hands of Bill Luce). Tamarack is pretty hideous.
Great soft hardwoods would include Basswood, Boxelder, "soft Maple" (Red-, Silver-, Big Leaf-, etc...) Aspen or even Tulip Poplar, Cottonwood, Willow, etc... I figure the softer, lighter-colored varieties would be best for beginners trying eccentric turning for the first time, so I didn't recommend harder species that would be no problem-o for more experienced folks. I would not bother with ring-porous woods like Ash or Oak --they just seem too grainy for something like this.
Where I live, Boxelder is considered a weed tree, even though its important for controlling stream bank erosion. People push them into the rivers just to get rid of them (and then the bank erodes, but you can't fix stupid), sometimes even the ones with burls on the trunk! That makes it pretty easy to source in many areas.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
Re: trees with puff paint
Brad Vietje
Wowzer -- that's more bleeding than I got by far. You probably have better markers that haven't been through the freeze-thaw cycles for about 4 years 8) Those are still really great enhancements -- they are starting to look like Christmas candies or cookies! Thanks for posting these little beauties.
Should be in the 40's today before falling back into the teens tonight.... I may get a chance to try one with spray paint.
Safe spinning,
Brad Vietje
Newbury, VT
Brad I think the softer woods would be harder for a beginner to cut the offcenter grooves cleanly. Takes a very light touch with a really really sharp skew. I tried the 3 point tool just to see and it tears the grain way too much.
Harder woods like Tulip Poplar is fairly easy to cut clean and it has some resistance to the cut which I think makes it easier to feel what your doing. Especially since you can't really see what your doing as the single side spins buy.
When I make the next one I will try the skew on it's side as well just to see how it cuts. Most of my club members are scared of a skew, even using the toe, which is what i did for my cuts.
Mike Potts
John, just a thought, how about a coat of quick drying sanding sealer then the pen?
keep it safe
Mike
Brad Vietje
Spray Paint Works
Brad Vietje
Different look entirely.
Took a short lunch break and turned a hunk of Fir 2x4. In this case, I sprayed before cutting eccentric arcs, but I still want to try spraying after the grooves are cut, then using a clean-up skew cut to leave the grooves painted. Homer only had enough patience to allow me to try one variation.
Here's the ornament:
And here's Homer (what a handsome and stately guy!):
Funny -- paint dries faster in the Summer ;)
Safe spinning,
Brad Vietje
Newbury, VT
Mike that's what I had suggested earlier. I do that before gluing pieces together with colored epoxy because I've had the color wick into the end grain and ruin a good project.
Re: Spray Paint Works
Brad I like the deeper grooves in this one. Makes the tree look more like a "tree". Not sure spray paint will go into the grooves. We'll have to try it and see. Quite often the flow of air going into the grooves will stop spray paint from getting in there. Don't know if a V groove would be different from a flat bottom groove but it's worth trying just to see.
