side grain red oak hollow form
Dick Coers
Always wanted to do a form like this, and the opportunity presented itself today. Got a phone call about a red oak cut down. 1:30 today it was a dead tree on the ground, 7:00 tonight it gets the first coat of oil. This is 90 degrees from my usual orientation. You can see the center of the branch on the sides, and the white sapwood band goes all around. Second picture is normal light, first picture is with the lights off, and an LED flashlight stuck in the opening. Close to a consitantly thin wall thickness. Once again, I'm giving credit to the optical hollowing guide. The thin walls let me sand it right off the lathe, but it was dead green when I started turning. Tiny cracks in the pith, they were there when I started. It'll be interesting the next couple of days to see what happens! 6 1/4" diameter.
Re: side grain red oak hollow form
That's a beauty.
If it were mine, I would continue to coat the outside hoping it would dry to the inside and shrink enough to avoid cracks. It may take on a slight football shape.
If it's that thin it might dry without too much cracking on the pith. I did one out of some other wood years ago and had pretty good cracking on both piths but it wasn't hollowed anywhere near as thin as yours. It will go football shaped but warping is good, it relieves the stresses that crack it. I would also keep oiling it.
I have to turn 2 spheres for a project that started many years ago. I have the wood just haven't taken the time to turn these. I need to get them turned and let them warp. I leave the pith in these because they will be painted and it won't matter if they crack, I'll fill it. The warp works in my favor for these pieces.
Good job. Let us know how it goes. Very beautiful piece
Brad Vietje
That's an "Ellsworth Football" !
Brad Vietje
... and a great job -- very nice!
Shrinkage should push the two end grain parts out to make a football shape; you got this nice and thin, so it might not crack at all.
Show us what it looks like in a few weeks when it's good and dry -- should be pretty cool.
Safe spinning,
Brad Vietje
Newbury, VT
Craig Daymon
Looks great Dick. Those cracks are one of the main reasons I put a blackwood plug in that Eye Bowl I made. Though there were cracks that extended beyond the plug that I filled with blackwood dust and epoxy.
I'm considering to switching to using Strait Line chalk, which comes in assorted colors, is nice and fine grained and mixes well with epoxy for my fills. It's really cheap too and the container is pretty convenient for storage. I used black before on a platter project to fill a fairly large hole near the rim. Worked great and still holding well after about 5 years.
Brad Vietje
'Nuther Cool Thing...
Brad Vietje
When you turn Red Oaks through the pith -- especially Black Oak and Pin Oak -- you get a really cool-looking 5-pointed pith in the center of all the growth rings. If you can turn 'em thin enough, you can avoid checks, and the 5-ponted star is a nice little added bonus.
Safe spinning,
Brad Vietje
Newbury, VT
Phillip Medghalchi
Dic, this is a beautiful work. I hope it stays that way and won't crack. I look forward to see what happens to it in few month. That is if you still have it and not sold yet.
that's nice, Dick
GaryG in MD
I've always liked turning "double bullseyes".
They have a certain "character".
Yours is a gem.
Letting it dry from the inside out (by oiling the outside or covering the outside with paper) will help keep it from cracking too much, and the thinness (particularly the uniform thinness) is an important factor too.
If you've already oiled it, don't be afraid to hit the pith centers with a bit of Thin CA. It won't show, and it can help stop the cracks from propagating until it gets dry. ...GG
