6 Axes Human Figure HOW TO *LINK*
charlie belden
Earlier I posted images of two multi axis human figures, along with what I thought would be enough info for anyone interested in trying a multi axis piece to be able to turn their own version. From comments, it was obvious that someone not familiar with multi axis turning would need a lot more info than I'd provided in order to turn one of these type pieces
higher angle shot
I've put up a web page that hopefully provides what you need to turn one.
Multi Axis Human Figure HOW TO
Re: 6 Axes Human Figure HOW TO *LINK*
You're Amazing Charlie!
Don Orr
Looks like you found something to do while trying to relocate your muse. Thanks for putting this together.
seconded: You're Amazing Charlie!
Rum
I like the way you think and maybe the way you write even better. Excellent writeup!
Re: seconded: You're Amazing Charlie!
steve worcester
Mark Sfirri influence?
Actually it was Barbara Dill
charlie belden
who provided us with a Structured Approach To Multi Axis Turning that revealed not only the WHATs but also the WHYs for understanding the underlying concepts of multi axis turning. Then Google's free virtual 3D modeling app - SketchUp - came along and provided the missing link to really understanding What Does What for multi axis turning.
Realizing that I didn't HAVE TO turn to round cross sections, but could turn ARCs, each axis with it's own profile - and have intersecting ARCs create lens shaped cross sections - or triangularish cross sections - pieces with edges - that can twist - THAT was when started getting really interesting. Being able to DESIGN a multi axis piece, then be able to actually turn it was exciting - and still is.
As for Mark Sfirri's influence his multi axis human forms have become iconic, but if you can turn a profile of your choosing in a spindle, you need only turn TWO in a single blank to turn your own version of his human form. Here's an example.
Lyle Jamieson
Lyle Jamieson
With all the experience with multi axis hollowing for my figurative series I have an above average aptitude for three dimensional thinking. But this work blows my mind, way too cool, beyond me.
To clarify -the example photo IS of a Sfirri Piece
charlie belden
I just used it as an example of how to identify the two profiles used for the piece and then to create virtual "turned" 3D objects for each, overlapping them as you would effectively do if you turned PART of each of them in the same blank on two parallel axes, and turned to their "common volume" - the human figure you're after.
You may be over thinking things
charlie belden
In this Sfirri type example, there are only two profiles to turn, producing only two outside surfaces - a front and back surface. The only tricky part is getting the right depth of cut on each axis - being only able to turn on one axis and one profile at a time.
Having a drawing, or a screen shot of the side view of a SketchUp model helps you see what you're after and what you've turned so far.
Here are two more images that may help.
The upper one is the piece after the "front" profile had been turned and the "back" profile was being roughed in.
The lower image shows the axis being turned on and the "back" profile being turned - that's almost done. There's still a flat spot at the shoulders. The head also needs some refining.
This stuff really isn't that complicated - or even hard to turn. And you can practice on pen blank sized wood - so you won't waste hardly any wood practicing and you won't need much room to store a ton of little multi axis "people".
Barbara Dill
This needs to be submitted to the Americam Woodturner!!!! Great job
