Servo motors, clutch motors.
TomD
Just redoing some motors for sewing machines. Typical industrial machine has a 1/2 or more commonly 3/4 hp motor with infinite servo control. They work really nicely. These are big motors like 3/4 hp motors on 14" bandsaws, as was once typical. They run about 95 bucks on ebay. Of course there are a lot of cheap drive systems on ebay of a conventional sort. Just wondered whether these motors would work well on a small lathe. My Harrison Union Graduate bowl lathe used to be considered a serious bowl lathe, standard motor in it was 3/4hp. More typically today it would be 3hp. Still just wondered if there was an application. For that mater, I am tossing the old clutch motors. Any of you who are familliar with Dale Stub's video, may remember he had his own clutch system, and it was pretty good, I had one on my General 8" x20" (at the bowl end), I wonder if the clutch motor would work on a lathe.
Re: Servo motors, clutch motors.
Re: Sewing machine motor on Youtube
TomD
Here is a youtube video where the guy used the 3/4 hp motor on his metal working lathe. Though metal lathes are different animals, I would say this pretty much is proof of concept since my only concern was guts of the motor, which is more of an issue cutting metal, though obviously this thing is only 3/4 hp and in that sense lacks guts. My Harrison bowl lathe only had a 3/4 hp motor capacity, but that was before people started peeling at modern rates. Still probably an optiion for spindle and light bowl lathes.
https://www.youtube.com/watch?v=w3DsyHWwPPU
Stuart Johnson
A few years back there was a lot of discussion about using motors from old treadmills. I don't know the size but they are variable speed.
Ken Vaughan
Ken Vaughan
Consew motors for industrial sewing machines have been adapted to lathes. These are 3/4 hp motors with electronics with them. The torque is pretty even across the speeds (not common for the cheaper drives).
Will probably adapt one of these when the motor give me problems on the Jet 1014 --
Several are using these on small metal lathes and mills.
Was just looking at some setups in the last week or two from metal working forum -
TomD
You are right about that, but I never found one at a good price, just as luck would have it. Here were have stuff you can order off the bay with free delivery for 100-160. So for those of us who don't get the deal, it is pretty sweet.
