Obviously I turn different that many others. I hear complaints about the Powermatic square headstock geting in the way. I've had mine for about 12 years now and the only times it's been a problem I think any headstock would have been a problem.
Can you all describe what cuts you do where the headstock is in the way. Just trying to learn what I'm doing wrong. Seriously, I'm sure you have logical reasons it just doesn't happen with my style of turning and what I turn I guess.
Whenever I need more room on the headstock side of my piece I use an extension on the chuck, between the chuck and the headstock. It gives me about an extra 6 or 7 inches of room between the chuck and the headstock, with zero runout.
Any time I need to do fine cuts close to the chuck. I too have a spindle extender but often my left shoulder need to be close to the lathe. Another example is to clean a bead on a bowl or other turning, near the chuck. To run the spindle with the grain one has to go from chuck to rim. I always prefer a pysh cut to a pealing cut and often use a spindle gouge to finish the surface close to the tenon.
Also that bulky headstock is often interfering with the tool handle in those cuts. This at least in my experience.
I just went to the lathe and working on a small bowl it came to my mind that another problem I had were the legs interfering with my feet. The VL3000 is completely flat. Nothing to bother your feet while you are dancing with it.
My 3520A had a groove in the headstock to allow for getting closer to the bottom of a bowl where you are twice turning, have returned the tenon, and reversed it for final finish cuts. Since I turn green to final thickness, never an access problem for me as the outside is finished turned before I reverse it. I have tried a few, and some times the 70 degree bevel gouges can get in there where a 45 degree bevel won't. Also, a dropped handle, high shear angle cut can work till you get far enough away for better access.
I turn the bowls around to finalize the foot This way I can use a spindle gouge sharpened at a 35 degree angle and do a push cut against the grain. Usually I clean it up and shape the foot using pull cuts with the bowl reversed. Then clean up that last 3/8 with the spindle gouge
I normally do a push cut working from rim to foot or close to the chuck depending on the shape. The. Reverse the bowl and finish the bottom. This keeps the headstock from being a problem
There are nine ways to skin a cat. The important is the result. The best situation in any case is a lathe that allows all the positions as easy as possible. Oneway, Robust and Vicmarc are one step above in my opinion.
Usually I don't have trouble with the Jet 1642 or Powermatic headstock getting in the way. However, when I work on some bowls or plates with complex toward the center, I have to work alternately on one face then the other to get the thickness and profiles right; there can be several dozen such alternations. Sooner or later the headstock gets in the way. Given that, remounting repeatedly would get old, waste a lot of time, and re-centering accurately could get problematic.
I never seem to have that trouble, either. I start and finish very nearly every bowl between centers, so I have no real access problem from the headstock. The older 3520A models were rectangular, but my 3520B has a beveled headstock. I sometimes work with my left shoulder leaning against that bevel, so I'm glad it's there. I've turned on OneWay lathes many times, and never found the round headstock any advantage -- maybe I've learned to work around the clunkier PM, so I just don't have the same issues a OneWay turner would have on my lathe (?)
The tailstock gets in my way sometimes, a heck of a lot more often than the headstock. Maybe I need a vacuum chuck?
A vacuum chuck? Since I got one (actually three From Oneway) my turning life has changed. The only problem I have with them is that with soft wood, butternut for example, even at a not too strong vacuum, the chuck leaves a compression sign similar to a burnishing mark.
I've made my vacuum chucks. I am always playing sealing materials The soft ones seal better especially on mildly warped bows but they throw them off center. Not a problem if you reshape the entire foot If the foot is already done then you can't touch it. On those I just clean up the very bottom
The stiffer gaskets aren't fore giving of warp but align better. They are also more likely to leave a burnish mark
I do like the square headstock top on my lathe. I am constantly putting small things up there I put my magnetic light up there and the magnet will hold small wrenches a d index pins etc
