New Powermatic 2020 *LINK*
Ray - Middletown, IN
Got this today. At least the notice not the machine, darn it.
Ray
PM2020
Ray
PM2020
:-) My 3520 with bed extension is about right
extension high or extension low? guessing low
How about a 2424?
David Gilbert
I think Powermatic made a mistake with the 2020. They should have released the Powermatic 2424. It is available in Europe as the Jet 2424. It appears to be a great lathe for bowls and such.
Re: extension high or extension low? guessing low
Jorge
Rum,
I have mine with the extension on the low position. The only time I used on the high was for a stairway project. In the low position is good for big bowls and a great place to lay the tools you are using.
Well I have a 3520A and it doesn't have the low position. When I made the Gun lamp it was 54" between centers. I barely had a long enough bed. In fact I've though of buying another bed extension for future projects.
I am going to convert my A to a B by adding the lower holes to the leg and adding a plate to the inside to make it thicker to handle that cantilever weight. I want to make some one piece hand mirrors and need a swing of at least 21" the 30" you get from lowering the bed on the B series would be perfect for me.
Vicmarc sells a shortbed lathe (16/24) and it's very popular. You can buy bed extenstions if you ever need a longer bed. Or I suppose when you downsize your shop later in life or due to lifes circumstances you could shorten the lathe by removing the bed extensions.
A lot of people also bought the Stubby because of it's smaller footprint. I think it's a good idea but I'll agree it should have been maybe 2420 or 2424 instead of the 2020. I'm guessing cost is a factor as well although I haven't seen the price.
Personally I'm going the other way. I'm going to try and get a bigger shop, not a smaller lathe. I like Nick Cooks 24" Powermatic that is about 9" long or whatever size it is. It's huge.
Re: :-) My 3520 with bed extension is about right
Philip Duffy
Absolutley right, John! P.
Price.
Doug Wolf
John, You said "I'm guessing cost is a factor as well although I haven't seen the price."
It looks like it's only $100 less than a 3520B. Unless space is not available I can't imagine buying it instead of the 3520B. Just slide the headstock of the 3520B down 15" and you've got a 2020.
Re: Price.
space can be a problem. When I slide my headstock down I have my back at the door. If I have the door open (which I must in the summer) then the door gets in the way of longer tools when hollowing bowls. Hopefully in my new shop the table saw and lathe are going in first and will have space prioritys. However since I will possibly have to deal with whatever I buy I may still have space problems. Ideally I'll build a shop but that takes money and if I find a house with a garage or shop already I may have to live with what I get. Still looking for that farm with a chicken barn
Re: New Powermatic 2020
terry quiram
Awesome. Congratulations Ray.
Craig Daymon
I wish there had been a JET 1635 when I bought my 1642. For my current shop space, it would have been much better than the 1642. I'm guessing this 2020 is meant to be a PM bowl lathe, or just a cheaper way to get a lathe with decent heft that you can add a bed extension to later. If I had 220 in my current location it might be of interest to me, depending on price.
Sergio
Well, in my opinion the best best of the new arrivals in the lathe industtry is the Vicmarc VL240. I had a jet 1642 and sold it to get a bigger lathe (Vl300). I vould not stand the square head. Often in the way. The VL 240 is going to be my second lathe when my addition to the shop will be done. It even has a dust port, something that I considered a very usefull safty implement.
Obviously I'm not affiliated with Vicmarc, only consider their lathe among the best at very good prices and the most overlooked.
fyi: low extension is 38" of swing
Rum
Might matter if you're going to use the factory tall tool rest.
I think it would be feasible to put the 18" extension low on the end of the 50" long bed extension (once you get the shop upgrade of course..). A couple of the pictures I've found it looks like its already pre-drilled for both the high and low mounts. If you got it now you could swap out the rear leg, use it as is and then swap them back and put the longbed on once you move.
I have the 18" extension (came with the 90th anniversary bundle) but haven't actually installed it yes - I'd have to remove/rebuild my sharpening cabinet for it to fit). If I end up doing some spinning wheels I'll have to add it in the low position to get enough swing. I've gotten really close on the length a couple of times, but have managed to squeak by so far.
Larger shop sounds perfect! Its on the list for most of us I think
NICE! I Agree About The 2424
Re: NICE! I Agree About The 2424
Roy
Not to be cynical or anything, but if the 2020 is like the 3520 you won't get that 20 inches between centers. I venture to say that the tailstock won't get much use.
Roy
