OT? Lose tools no more. High tech toolbox *LINK*
Craig Daymon
Just watched this video. Still a prototype at Intel where they lose over $35K in tools each year, but all the parts are off the shelf and the project was developed with free, open source software.
Maybe someone will find this useful.
High Tech Toolbox tracks tools and who took what
Re: OT? Lose tools no more. High tech toolbox *LINK*
I have one of those, Sort of......
About thirty years ago when I started doing Home Inspections I realized I used about ten tools and was guilty of leaving them behind. Some of the them were fairly expensive. I got a Pelican case and carved out a spot of each tool. I look like I have arrived to disarm a bomb, but very few lost tools since then except the time the builder's crew stole the entire tool box while I was in the crawl space. The only light sensors I have with mine are my eye balls.
Low Tech Red Neck Solution
jeff Willaford
The Lending Nail. Drive a nail in the wall by the shop door and cut the head off the nail. When someone takes a tool put their name on a piece of paper along with the tools they took. Add the date if you like. Impale the piece of paper on the nail. When they bring the tools back pull the paper and toss it into the trash. Taught to me by an old friend from PA may he rest in peace.
That said.... cool toolbox but I don't think I want one. Thanks for the link.
Jesper, Denmark
Re:Typical Intel -
Jesper, Denmark
Spend $5000 to solve a $50 problem.
I supplied some pollution control systems to them many years ago. They insisted on having thermocouples and digital local read-outs where a simple thermometer would have done the job.
Guy Bratt
I was on a tour of the Air National Guard base with the cub scouts years ago. In a hanger I saw a rolling tool box with foam matted drawers with the tools cut in. When one was removed there was a blue space. The guide told us when you were done working you had to check each drawer, if you saw blue, you probably left the tool on the aircraft and had to go retrieve it.
ebd
ebd
The mill (Westinghouse Airbrake) my Dad worked in had an equipment and materials cage. You had to sign everything out and back in. Held vastly more than that small box and wasn't subject to battery failure, hacking, salt water, etc. Sometimes low-tech whupes the pants off high-tech.
Craig Daymon
I would suspect that, based on the tech in use, when it is done it will cost not much more than $50. (Nothing close to $5000.) Also, the current level of tool storage is greatly limited by the fact that this is just a proof of concept, not a functional unit used on a daily basis.
Obviously, if the company is losing $35,000 of tools per year, this is a big issue for them.
Are there methods of work that could accomplish the same, yes. But if you want to track who has what tool out that likely requires a cage situation, which then requires staff to man it.
Tech hardware is getting very cheap. There is a guy building a CAT scan priced at less than $1000 and makes all the plans and software avaiable to anyone that wants it. (Granted, not a full body scan, but it can certainly be scaled up.)
What is doesn't solve is "where is my tool"
I agree
Stuart Johnson
I'm the only one that goes in my shop, I'm the only one that uses my stuff. So why the hell can't I find it?
