New turning - Finishing question
Craig Daymon
I just finished turning this new piece. Really happy with it, so I don't want to mess up the finish. I will be using Waterlox. I call it, "Eye Bowl #1", and expect to make a couple more. Masur Birch, African Blackwood and Maple.
The finish issue has to do with the collar. It is Maple (because I didn't have a large enough piece of side grain blackwood or ebony). It is colored black using permanent marker, which really doesn't seem all that permanent. I know I should have taped off the glue area and put finish on it before assembly, but I didn't. The collar doesn't look black, like it should. Has more of a somewhat metallic iridescence to it. Suspect it will look more black with a coat of finish on it.
So, the finish quesiton is what's the best/safest put a coat of finish on the collar without bleeding permanent marker onto the Masur Birch?
Here's a pic of the piece. A bit distorted in shape because I was too close when I took the picture.
Re: New turning - Finishing question
Don't rely on us, do a test. Take some scraps and color it and see if it bleeds. I have done fake bark edge bowls using permanent markers to color the edge and sometimes lacquer will make it smear if I'm not careful. Don't know about Waterlox because I don't use it.
You can color the wood with more coats from the pen to make it darker but it will still have a slight brown look. A better choice would have been india ink but it's hard to keep it from running when you apply it.
Dick Coers
I'd suggest a spray application for sure, and a real spray gun not a rattle can. You seem to suggest only solvent based ideas, do you want the Masur to end up with an amber tint? More than amber since you mention Waterlox? With the spray gun, you can dust on the first coats, slowly building the finish. If you flood on a wet coat right away, you have a better chance of bleed. Acrylic finish would be the safest, and if you have to use a rattle can, artist fixative might work well. But I always stress this, and John told you as well, EXPERIMENT ON SCRAP! Never, ever, try new finish on a completed project. I broke my rule for the last time 1 1/2 years ago. A beautiful red dye and colored piece, that has wipe on poly peeling off of it in small areas.
Phillip Medghalchi
Craig, first of all that is some stunning piece of work.
About the finish. I have used permanent marker to write on the bottom of my bowl which was finished with lacquer and it's been form earlier this year and i went to check and read for cataloging my work and found out that it was speared to the point now I can not tell when it was finished.
I was going to suggest India ink like John and Dic did. However, I am not sure if you have to sand the ring on the top first then color with the ink. I found different tip pens at Hobby Lobby in my town. If you want I can take a pic. of it so you can show them exactly what yo are looking for.
I haven't had much of luck to get a smooth finish with the can sprayer. I think it doesn't do as good a job as real sprayer does. You may want to ask Dic. if a smaller air brush spray gun will work. And, do experiment on scraps first, your piece is too nice to be ruined because of finish.
Most beautiful job, look forward to see it finished. That masur birch is way cool'
bowlman
Craig ... if you do try India ink, I suggest that after you experiment on scrap, you turn the piece upside down and apply the ink from the join line to as much of the collar as you can reach. If you have the time and energy, you could build a small stand that would "suspend" the piece ... a large round piece of wood as an upright attached to a substantial base. Make it tall enough that you can reach all parts of the collar, inside and out.
Also, if you use lacquer, either out of a rattle can or from an airbrush (get a cheap one from HF) ... after you apply several thin coats, you must then sand back (I hand sand with water and one small drop of dawn as a my wet mix and I use one grit high than the final sanding of the bare wood) and remove all the shiny parts. This will create a perfect surface for the final coat which will be so shiny ... and a bear to photograph!
Craig Daymon
Thanks for all the advice.
I have no india ink and the marker has already been applied. I should have used the black marker from my set of Prismacolor markers, rather than the Staples brand permanent marker. Art Liestman uses these with good success, though he usually puts burn lines between colors and I don't recall what his finish of choice might be.
I will be using Waterlox to finish it and I do realize it will add an amber tint to it. It should also make the iridescent side grain pop a little more than it already does. I don't have a spray gun or an air compressor and I'm not very good with a spray can.
I have a drying stand I created last night (though I have done this before, just can't find it) by putting a 1/2" dowel into a board that will serve as a base. (The dowel is rounded over and sanded on the contact end, which should minimize the contact point and lessen any chance of damage to the piece from a sharp edge.)
I will use blue tape on the outside and finish the collar first, allowing it to dry a day before applying any finish anywhere else. I can hold the piece while apply the finish, using a glue brush. I don't intend to so much brush it on as to dab it and get the collar wet with finish and completely covered.
While drying, it will be orientated with the collar facing downwards, eliminating any chance of staining from running. It will sit with the dowel end inside the bowl, freely resting on a single point (if I rounded the dowel perfectly.)
I'll post pictures of the final piece and explain how I created it.
Thanks again.
P.S. My usual finishing stand is a large dry sponge that I poke toothpicks into in a pattern and number sufficient to support the piece.
Emmett Manley, Lakeland, TN
The best black coloring agent I have found is USMC (US Marine Corps) Black leather dye from Tandy Leather.
The best pens for writing on the bottom -- Micron pens with archival in.
The best drying stands -- pieces of old bandsaw blades bent into "V" or other configuration.
