Re: nice work
bowlman
The boats start out as 2 slabs, 6 inches wide by 3 inches thick. They are planned and jointed and glued together with a paper joint in the middle. To help with alignment and to avoid "creep" when clamping up, I drill a hole in each corner and, as i begin to bring the 2 halves together, I insert an appropriately sized dowel as a registration pin. This eliminates the creep. When dry. I mount between centers and turn a long cigar shape and then sand well. Turn the ends at the drive and tail stock down to as small a diameter as you dare. remove from the lathe, use a chisel to separate the 2 halves. Now all you have to do is carve out the inside.
When doing the inside, remember that authentic dug out canoes purposely left a bit uneven, especially when compared to the outside. The reason for this (as explained to me by a friend who has studied native Amazonian tribes), is that the natives normally go barefoot and bare feet on a really smooth woooden surface just invites a slip and a fall. So, the slight irregularites and "rouhjness" inside the boar actually serve a useful purpose.
