What are the best laser pointers to use in my constrained hollowing rigs? You know, the small cylindrical laser pen lights. The ones I have seem to have developed all kinds of little problems: the switches don't stay on, or they constantly flicker on and off ,or the point of light keeps getting bigger so that they loose their accuracy.
I have been using lasers for 18 years now. I can not tell you what to buy. Mine are good, and if they fail I replace them. You can spend a lot of money on a lease or a little money. What I would advise to stay away from is the cheepy lasers with watch batteries from places like big box or discount stores. The watch batteries go dead in a hurry and the replacement batteries cost more then the laser.
The size of the dot is not an issue if you use my techniques. The laser is not doing the measuring, the gap between the laser and the cutter is the measuring device.
The size of the laser dot can be reduced and a lot of the flare eliminated by shining the laser beam through a small hole placed about 1/4" from the laser.
Here is a composite photo showing the difference:
The photo shows two of my shop-made laser holders with the laser installed in one. The laser dot falls on a sheet of burgundy poster board about 3" from the laser. The hole is 1/16" in diameter, drilled in a thin piece of plastic and attached to the holder by a couple of screws.
On the left side of the photo the laser has been slipped out of the holder and is just hanging in the air. You can see that the dot is much bigger and the flare is greater.
I used the "hole in the plastic" method because it suited my holders for the laser module. If you have a round laser-pointer style laser, it should be easy to turn a small cap to fit over the end of the tube, and then drill a small hole through the center of the cap. Secure the cap to the tube with tape, CA, epoxy, or whatever.
Incidentally, the wooden holders mount on the Monster hollowing system and the laser module is the one supplied with the system.
Looks really good Doc. I haven't tried that yet but have made a few pin hole cameras over the years. What we do to make the hole cleaner and reduce flare around the edges of the hole is to drill it in brass shim stock. Then sand very lightly both sides of the hole. this gets rid of the slightly burred edge of the hole and makes a cleaner dot (all photos are really just many small dots) that produces a sharper image.
I'll have to give your method a try when I mount my new laser that I purchased way to long ago and haven't taken the time to build the new holder.
