Crotch Pecan
Crotch Pecan
Crotch Pecan
Phillip Medghalchi
I have this piece ( pic. will be posted tomorrow when it is sunny and I get a decent pic. of it.
In the last two tries, I made a mistake and did not pay attention to the orientation of the crotch part on the lathe and as result I missed most of the beauty of the crotch in my design. I like to get advise as what is the best way to cut this to reveal the crotch section and orientation of the blank after the preparation for the lathe?
thanks for any advise.
This the one which I have done before and missed the dramatic effect of the crotch inclusion. As you will notice the part of crotch line shows obve on the under cut rim.
Second one I did which has more of the cortch section incorporated into the design. the line on the rim is not a crack.
Re: Crotch Pecan
Re: Crotch Pecan
john Veerkamp
You want to cut the blank so that the crotch figure will be in the bottom of your bowl..make the cut the depth of your + to one side of the crotch. The bottom will be closer to accommodate the thickness of the bottom = enough for what ever mounting method you use. Mount it between centers to get the orientation you like.
Re: Crotch Pecan
Re: Crotch Pecan
Phillip Medghalchi
Thanks I try that. hopefully I'get a satisfactory result this time.
Re: Crotch Pecan
Re: Crotch Pecan
Imagine the log with the fork in it is a "Y" Look on the three ends and locate the pith on each. Try to saw through all three making two "Y"s. The sawed face should reveal the flame. Often the flame is not very thick and unless you are making a very shallow platter it might be better to saw to one side or the other of the plane of the three piths and turn the thicker piece to reveal the flame. Try for one good one rather than two poor ones.
Re: Crotch Pecan
Re: Crotch Pecan
Phillip Medghalchi
Thank you Barry, I'll post before and after pic. to make sure I get it right.First time is a challenge,but second should go smoother. Thanks again.
