Which oil for Walnut
ken chase
I plan to oil and wax my natural edge black walnut bowl but don't
know which oil is best. Suggestions please
Thanks
Ken
Re: Which oil for Walnut
it depends how shiny you want it
GaryG in MD
Any oil will work, but, first, I'm assuming you want a DRYING oil.
Watco Danish is fine if you want a "dull" finish, but it is thin and takes a long time to build if you want a shinier finish.
I prefer Bush oil because it has 4x more solids and requires fewer coats.
I like to rub mine out with the Abralon series -- 500, 1000, 2000, 4000.
That gives a nice satiny sheen that still looks like wood.
But it shows every scratch (DAMHIK), so you have to be very careful as you work through the grits before applying the oil.
You can certainly use a real tung oil such as Behlen.
Bear in mind that if your product ends with the word "Finish", it can be anything, and is often anything BUT what the words before the word "Finish" imply. They will generally have a varnish of some sort included in the blend.
Remember that the rags/paper towels that you wipe it off with must be handled as if they were fireplace ashes. Drying oil is exothermic and can cause spontaneous combustion.
Let's see it when you're done! ...GG
William Duffield
It seems to me that the natural answer would be walnut oil.
john Veerkamp
I agree. Mike Mahoney's heat treated walnut is what I use on 90% of my bowls. Dries beautifully. I then wax with various types depending on how shinny I want it.
Re: Which oil for Walnut *LINK*
Mike Brazeau
I like Watco Danish Oil on walnut. I do a wet sand with 220 or 320 to fill the grain and then wipe across the grain when almost dry. Buff only with light application of Tripoli on the wheel. White diamond paste may catch in the grain. Danish oil really gives life to the color and grain. Have a good example at the link below in The Turned Bowls album, of a walnut piece that ended up in The Four Corners Exhibit at AAW St. Paul a few years ago.
The Joy of Wood
don stephan
My experience with a shop mixed Danish oil (equal parts mineral spirits, boiled linseed oil, and Pratt &Lambert 38 gloss alkyd varnish) was that it didn't come up to a full shine. I was told it was because the linseed oil keeps the mix softer. Now I simply use equal parts mineral spirits and P&L 38 gloss as a shop mixed wiping varnish and get a gloss sheen, depending on the wood, after 4-6 applications.
