Activator musings
As some of you probably know I use activator on my CA joints for my hand mirrors. The reason I do is it makes the joint brittle and I can break off my scrap wood mounting blanks without damaging the good mirror blanks. If I don't use accelorator it will almost always pull wood away from one of the blanks instead of breaking at the glue joint. That's why I know it works.
What I'm finding (except I don't know how to really test this) is that some activators seem to make the joint more brittle.
I was using insta-bond aerosol activator in my class this last weekend and several students had problems with the joint breaking and they weren't getting catches. I never had the problem at home using E-Z bond accelerator. I also have some Stick Fast activator and it seems to work similar to the E-Z bond.
Could it be the Aerosol or is the chemical makeup of that brand. I've also had bad CA cause the same kind of brittle joint but I know my CA was good because I had been using the same bottle just before leaving for the trip.
I can't think of a good way to test this theory without getting really complicated. I suppose some kind of swinging hammer so it would hit each piece with the same force. increase the height of the swing to increase the impact. Don't know if I'll actually do this but it's an interesting thought. There would probably be too many other variables such as the amount of glue applied, how flat the mating surfaces were, etc.
