Speed Controller for Delta 1220 Lathe Problem
Peter Toch
A friend of mine asked me to take a look at his Delta 1220 Midi Lathe (Delta Model #46-460 VS) which has a variable speed controller which has stopped working and to see if I could repair it for him. I disconnected the motor from the speed controller and it ran fine when connected it another variable DC speed controller I have. Conclusion, motor good, speed controller bad. Delta Parts has been less than helpful and claim that a replacement controller circuit board is no longer available. Inspection of the defunct controller does not show any obvious signs of damage such as burned areas or components or any classic "electrical burnt odor."
Questions:
Has anyone run into this or a similar problem with this lathe?
Were you able to find a solution to replacing or repairing the circuit board?
Does anyone know of someone that can analyze and repair the board?
Does anyone know which of the components on the board are the most suspect?
Any suggestions are most appreciated. Thanks, Peter Toch
