I just got back from an almost 3000 mile trip around the midwest. After I left Tennessee my gas mileage dropped from 27 to 24 or 25mpg. It stayed that way through arkansas, missouri, Oklahoma, Texas, Mississippi, Alabama and Georgia. I filled up in Chattanooga and it jumped back up to 27mpg. Interesting. I used alcohol gas and I know that if I use alcohol free gas I get about 29mpg. So I'm wondering. Do they add extra alcohol or something out west to their gas.
The quick answer is yes, each state sets its own mixture requirements for gas. Regionally, gas is usually pretty standardized. The area in which you drove probably had very similar mixtures - at least starting at the refinery they did.
You will get about 25% fewer miles from a gallon of pure alcohol than you will from a gallon of pure gasoline. The most common alcohol-gas mix is 10% alcohol (by volume) to 90% gas. So for 1,000 gallons of mixture, there would be 100 gallons of alcohol. Different states do mix in different ratios with E85 being 85% ethanol to 15% gasoline.
Unfortunately, alcohol and gasoline don't blend. There are other chemicals mixed in with our gasoline that do blend but alcohol just mixes. That means over time, the alcohol and gasoline can separate in the storage tank, so you never know what actual mixture of gas and alcohol you're getting. The longer the fuel sits in the storage tank, the more likely you are to get a higher or lower mixture of alcohol and gas.
If you are in an area that has E85, most manufacturers recommend you choose whether to use E85 or gasoline and do not mix and match. When we put gasoline in our tanks, over time varnishes stick to tank walls and the insides of fuel lines. High concentrations of alcohol can dissolve these deposits and they can foul fuel lines and filters.
John, i was going to tell you same thing, every time we went to NM, to see my in laws their octane was 86, or 85, then in S. TX is 87, and I was getting different gas millage going up to NM or coming down back to San Antonio. the places you told me you were at during this trip I am sure had all different altitude that effects your overall millage reading. then did you take any load to your demo and came back with less load, that can cause it too.
In Wisconsin, when we switch to winter blend, I lose about 5 miles per gallon--sorry John--you were subjecdted to the nasty winter blend we have up here.
65 mph gas with 87 octane versus a heavy right foot 75+ mph with 85/86 octane just might do it. I don't know if they have gone to winter blends yet. We seem to always have major shortages because of the switch. The refineries don't seem to remember the twice a year change.
When I was growing up as a kid I used to chew on my pencils. Apparently they had lead paint and it all went to my right foot. I drove almost the entire trip at 79mph.
It was quite windy for almost the entire trip so that could have been a factor but not on that many tanks of gas.
