WOP finish
WOP finish
WOP finish
Phillip Medghalchi
Now that the temp. has dropped down drastically and some of you who live way further north than me dealing with colder weather, how do you apply WOP and let it dry?
I applied a first coat three or 4 days ago and brought the piece inside the house, and the inside temp was kept at 70 Deg. with central heat going on, however, it took until yesterday that I noticed it's still little tacky to the touch.
I can not do the in between coats light sanding with 400 grit until this dries.
How do you guys do it in temps. much colder than Deep S. TX? Do you add any accelerator to dry it up faster?
Any help is much appreciated.
Re: WOP finish
Re: WOP finish
Mark Trenier
I live in Wisconsin--I have no problem with the satin finish, but I can't get the gloss finish to work at all below 50 degrees. I just stick with the satin finish and apply once every 24 hours. Hope this helps.
Re: WOP finish
Re: WOP=Wipe On Polyurethane????
Re: WOP finish
Phillip Medghalchi
Yes Adrien, you are right. Sorry I should have been more careful not to use abbreviations, not causing any confusions, my bad.
Re: WOP finish
Re: WOP finish
Phillip Medghalchi
ark thanks for your reply, I didn't even think of that and didn't know that satin works differently. Mine is gloss. so that may be the reason? I wonder if they use different carrier in the gloss than satin formula?
Re: WOP finish
Re: WOP finish
Juergen
Did you use WATCO or something similar before applying the WOP? If so, it might not have cured sufficiently. Suggest you just be patient and give it a few more days.
Juergen
Re: WOP finish
Re: WOP finish
Phillip Medghalchi
Juergen, yo wrote: "Did you use WATCO or something similar before applying the WOP"
The WOP I am using is made by MINWAX, and the only thing I did was tha I had lacquer sanding sealer on it. Did I do something wrong that is causing this incident?
I will leave it until end of the week that temp. supposed to get up high as about 77 Deg., which would help it to cure. I am not in a big rush. the bowls were finished a long time ago, and I am just getting around to putting the actual finish on them and I picked the wrong time for doing that.
i was just asking the qsn. above to see what is the techniques that turners in colder climate do? Or do they cease putting finish when it is cold?
thank you for your reply above.
Re: WOP finish
Re: WOP finish
Dwight Rutherford
How fresh is the WOP? I and others have had WOP and other finishes go bad if they have been open for some time and been exposed to the air. Biloxigen or Stop Loss bags help extend the life of many finishes. Maybe someone can address this issue better than I.
Re: WOP finish
Re: WOP finish
Phillip Medghalchi
Dwight, I bought it I guess two months ago and just opened it in mid Oct. thanks for the tip, I make sure and use the bloxigen I bought, but it has the lock down black cap and very small,, so I have to figure out who to shoot that bloxigen into it.
Re: WOP finish
Mark Trenier
Phillip--this is the first time I ever used High Gloss during the winter. It does have different driers in it, and even after I brought it into the 70 degree warmth of my home for a week, it was still tacky. I did recoat it with gloss and after 24 hours, it was fine. Just my two cents. All I know is what I have experienced. Good Luck.
Re: WOP finish
Phillip Medghalchi
Thanks Adrien. Hopefully, we get an answer by Monday when most experience turners can see this. I like WOP and like to keep suing it for the ease of application.
Re: WOP finish
Re: WOP finish
Phillip I am using WOP Glossy right now. My shop is about 60 degrees. I keep the can in a heated cabinet that never gets below 50 degrees. I shake the can, then apply a liberal coat of the poly. When I get an even coverage I wipe as much off as I can. I apply several more coats like this but might not wipe as much off on the next layers. Still I wipe quite a bit away. I think it works better when I use multiple thin layers. Less streaking and a more natural look. I don't like the thick plastic look.
I sand to at least 400 grit. on some pieces a lot higher. The more I sand the fewer coats it takes but on most pieces 400 is fine. Some woods simply require sanding to a higher grit.
If I still have some streaking after I get the build I want I will use the Beal buffing system or 4/0 steel wool. The wool gives it a soft satin look. If it's too soft I rub in a layer of Johnson's paste wax. If I want it more glossy I just use the Beal system. Of course if the last coat looks good I don't use any of the above.
