Old work - swifts (more yarn tools)
Rum
As a follow up on Stevens most excellent spindles.. Here is another set of yarn processing tools I made a while back. These are "yarn swifts" (specifically "umbrella swifts") for wrapping hanks (skeins) of yarn around to it organized while winding from the swift onto a ball winder or spool.
C&C, Q's and suggestions of course welcome.
Not just wood turning but that was definitely the more interesting part of the project (for me at least since it was one of my first "get back into turning" projects in the 20 some years since I last did it in high school). The shaft (of which the clamp mechanism is cut into as one piece), three floating rings, two "clamp" knobs and the press on top piece were all hand turned (for each one).
Although (imho) pretty; these do have a few serious functional issues:
- They're to large. The arms are about 16" long, closer to 12-14" would be better. The larger swifts are harder for folks with shorter arms to manage getting the yarn on and doesn't actually hold a skein as well as a smaller unit would. The weight also causes a bit of lag on start up.
- They're too heavy. I did an "overly good" of a job allowing them to turn freely so they don't have enough tension once spinning (and to much when starting because of the weight).
- A better locking mechanism for the bottom collar which holds them in "expanded mode" would be nice (ideas welcome). I just used a turned knob embedded with a bolt embedded so you screw it down for friction against the upright shaft. This works but requires three hands to hold the swift open, yarn in place and tighten the knob at the same time. Allowing the upright shaft to tilt would also be a nice design feature with a side effect of mostly solving this. Something more gentle on the shaft would also be nice (its not to bad since I eased the end of the bolt but still leaves divots if you over tighten).
- A looser coupling on the tips of the arms would allow the arms to float up/down easier (three rings instead of one or just straps/string to tie them together). I was planning on three rings per but that would have meant cutting and soldering ~150 rings instead of "just" ~80 rings so was loosing motivation by that point
