ADVERTISE HERE - FREE TRIAL
safely cutting ound log on bandsaw
ken chase
Don't want another trip to emergency and looking for fixture or jig recommendation to allow me to safely prepare a log section on the
i8" Band saw. A product recommendation or plan for homemade will be greatly appreciated.
Thanks
Ken
Re: safely cutting ound log on bandsaw
Ric Taylor
Ric Taylor
Ken,
I made mine by doing a google search for bandsaw log cutting jig, and some variations of those terms. Several different designs will pop up, and you can copy one of those or modify those ideas to suit your needs.
Mine works great and I feel much safer.
Ric
ken chase
Thanks. First video I found was great. Going to start work on it
soon as I pick up the material. Much appreciate the advice.
Ken
Steven Antonucci
I start with a chainsaw
steven antonucci
I'll take my round log out on my saw horse, and make 4 cuts (one either side of pith, and 2 more parallel just below the bark on either side). You should end up with 2 bark slabs, a pith slab, and two turnable sections that can safely be put through the bandsaw.
The pith slab will often get two more cuts to eliminate the center and the 2 quartered sections are saved for handles.
Steve
Geoff Whaling
Now that doesn't sound good. Hope you are OK.
I use a variety of simple sleds to hold work pieces & logs for cross cutting or ripping.
"Rip sled for band saw" or "cross cut sled for band saw" searches will find plenty of examples in Google.
One of the most dangerous operations cutting round logs on the band saw is when a log section is stood on its end and the diameter trimmed so the band is effectively cutting in rip mode. It is definitely not recommended but turners do it and I have seen some very nasty finger & hand injuries from this practice.
Generally severe hand injuries from band saws occur as the cut is commenced; when the band unintentionally exits the wood early; at the end of the cut as the band advances unexpectedly; or due to the work piece (log or blank) moving unexpectedly or failing (splitting).
Simple controls like using a sled to secure the work piece, removing loose bark etc, keep hands and fingers well away from the band and also prevent damage to expensive band saw blades.
Jeff Smith
I made one from plans on the WOOD Magazine website about four years ago. It works great. I think I still have the file for the plans somewhere. I'm pretty sure it's still up on the site somewhere. It was part of an article on reclaiming wood from urban blowdown, I think.
It's not a jig I use often, but when I need it, I'm glad it's there. Nothing else works as well.
Lyle Jamieson
Lyle Jamieson
Im going to take this in another direction. A band saw is the wrong tool for turning. I NEVER use a band saw for turning. A band saw is not designed to do thick wood and not designed to cut wet wood, sled or not. Besides it is not safe. I want to be in control and rough off the turning blank on the lathe. I start between centers on the balance point and slowly sneak up on the shape and adjust the axis as I see what the tree is giving me. You go to the band saw, and Ill go to the lathe. Lets see who gets round first. . .Ill win. But more importantly, Im having more fun than you will be worrying about getting hurt on the band saw.
Ive done this often when I do all day turning demonstrations. I ask how many there have hurt themselves or had close calls on the band saw. A large majority of the attendees raise there hands. Im not going to be one of them.
Mike Peace
Mike Peace
"A band saw is the wrong tool for turning. I NEVER use a band saw for turning."
Lyle, that is pretty strong blanket statement that no turner should ever use a BS for cutting any turning blank. I would not disagree that it might not be suitable for the turning you do. But many turners do a much broader range of turning including spindle type turning. IMHO, I would suggest that final cutting of spindle stock from the center piece of the log after cutting out the middle with the pith with a chainsaw is more suitable to a BS than a chainsaw. I love my Sthil CS but I do lots of blank preparation on a BS when I feel it is the more suitable tool.
I do believe there are safe ways to cut a variety of turning stock on the BS. Using the correct blade with few teeth and an aggressive set designed for turners cutting green stock helps. I am a believer that in turning, one size does not fit all. Strong blanket statements from "experts" without a little more context can lead novice turners in the wrong direction.
Lyle Jamieson
Lyle Jamieson
You are right, kinda. If you are cutting up kiln dried lumber then you are not using thick, wet, wood. If you want to use a log and it is thick wet wood I would stand by my statement that I would never use a BS. For segmented work, for pens, for finials etc. the band saw is OK but I doubt that is what the thread is about.
Taking advice out of context
Geoff Whaling
Taking advice out of context is one of the issues demonstrators & experts have when viewers of their demos take what they heard (or read) back into their own shops/sheds.
One of my concerns is that many new turners have had very little exposure to using machinery, hand & power tools before they took up wood turning. So they have acquired little of the "common sense" more seasoned wood workers / turners and demonstrators take for granted or assume the audience posses.
The BS has a place and is a more "suitable" tool for most wood turners than other options. Unfortunately few turners understand the hazards associated with using chainsaws / band saws / hand tools or large untrimmed wet green wood blanks on the lathe.
Its a learning process, so it is far more beneficial to assist turners to understand the hazards and the how and why "expert" turners choose to complete a task they way they do.
