Worm holes
Worm holes
Worm holes
Ernie Miller Topeka
How do you clean out worm holes in a turned bowl other than using dental picks. it seems to take forever to clean out a bowl. I spent over 2 hours on this one is there any easier ways?
Re: Worm holes
Dennis in Southern Oregon
Re: Worm holes
I have used a Dremel tool with a small cutting bit with some success.
Dennis
Re: Worm holes
Re: Worm holes
Dwight Rutherford
I use a variable speed Dremel with a round nosed dental bit. Run at a relatively slow speed. Get free worn out dental bits from my dentist.
Re: Worm holes
Re: Worm holes
Lloyd in Mississauga
I tend to use a small screw driver to fix glasses as a pick, and my airbrush to blow out the holes as I tend to get really light headed after the first 15 minutes of trying to blow away the dust myself.
They were some big arse bugs.
Re: Worm holes
Thanks I will hit the dentist up
Ernie Miller Topeka
I have more of this ash and several other wormy woods hiding out in the spalt pile.
Re: Worm holes
Steven Antonucci
I made a pick from a sewing needle
Steven antonucci
If you can loosen the frass up, you can blow it out with a compressor. I loosen on both sides of the hole until I can push the needle through. Once the needle can go through, the compressor can blow it clean.
S
Re: Worm holes
Re: Worm holes
robo hippy
Pressure washing does a good job, though messy. I haven't tried my Water Pick yet, but for smaller jobs it may work. The compressor never seems to get much out, and for sure the picking is a pain. That little vibration water pick thing the dentist uses on my teeth at the gum line seems like it might work.
robo hippy
Re: Worm holes
Re: Worm holes
I use a small drill bit. Any size that will loosely fit in the hole. Pick with it and spin it with my fingers. Then blow it out with the compressor. Good to wear good Eye Protections. The compacted frass seems to have a talent for finding eyes.
Sometimes wetting the bowl with work. The frass will expand and come out like a little eruption. Apparently it depends on the type of bug. Sometimes doesn't help and may make it worse.
My dentist always looks horrified when I ask for worn out bits and picks as if I am trying to steel his very livelihood.
Turning those bowls fairy thin seems to help. Easier for the picks and air to n=find its way through I suppose.
Re: Worm holes
Dick Hines
Re: Worm holes
Dick Hines
I will let the piece dry a while and blast them with 120lbs of air. It will not get all the bug s... out but it's faster than picking.
Make sure you have eye protection if you try this.
Re: Worm holes
Re: Worm holes
Sergio
Never tried myself but soda blasting might work. In fact I'm considering using it .
