Sandpaper.
Dick Hines
Don't go to HD looking for Norton sandpaper. They don't carry it in the stores anymore. HD and Lowe's are now both caring 3M. Bummer.
Sandpaper.
Dick Hines
Re: Sandpaper.
Dick Hines
Well I bought some of the 3m paper today. The box stores are way closer to me than the Woodcraft.
The 3M seems to hold it's edge well. Have not used all the grits but the ones I did use seemed to work well. Will have to do more testing before I change.
Re: Sandpaper.
Phillip Medghalchi
Dick, 3M has been around for along time and I don't think they would ruin their reputation over shutty sand papers. I have used them before and they held up better than other brands that i used. then I may be wrong. I think you have to use the right paper grading for the particular application.
Re: Sandpaper.
I order my norton 3X from woodcraft. I love that paper
Re: Sandpaper.
Dick Hines
I have been using Norton for years. I guess I could order it but I seem to wait until I am down to one sheet before I think about getting more. It's a 90 mile drive to Woodcarft and back. The box stores are only 5 miles. I will test the 3M for a while or at least until I go to another turning meeting.
Re: Sandpaper.
robo hippy
My local Ace store quit carrying it a year or so back. No one knew why. I was able to find it at a paint store. The clerk was looking for 3M but found the Norton 3X, which I think is a lot better.
robo hippy
Re: Sandpaper.
It's 100 miles to the nearest woodcraft for me. In fact I have one just about 100 miles in 3 directions. What I do is when I get down to about 8 or 10 sheets on one grit i will check on the other grits and order several boxes.
Re: Sandpaper.
Charlie Drake
Hartville Tool is a good source for 3X paper and they have free shipping (and a Woodnet discount if I'm allowed to say that).
Re: Sandpaper.
Don Orr
Bruce Hoover at the Sanding Glove has Norton 3X at great prices for 20 sheet packs. Just sayin.
Re: Sandpaper.
Mark Paulley
I use the paper Vince Welch at vinceswoodnwonders and he goes to many of the wood shows and sells on line. His response is quick and prices seem to be really reasonalable. He also has various types. I do not get any type of payment from Vince for stateing my opinions.
Re: Sandpaper.
Dick Hines
Did not know Vince sold sheet paper. Will have to check his sight.
I would still like to have a local supplier though. Some time I let my stock get to low and I run out before I can get to Woodcraft that is a hour away. Running 12 round trip was not a problem.
Re: Sandpaper.
Phillip Medghalchi
Dick, if you do not want to run into this problem again and find yourself running out of the paper when you need it most, cut some Red Cardboard sheets that you can buy at your regular office supply, walmart or anywhere you can find them then cut them to your sheets size and put them on top of the 15th sheet from the bottom, when you see that color coming up on you then it's time to order it so, you won't run out when you need it most. I hope this helps, although, somewhere else I was told that I am new and so I shouldn't write these messages, they should be very short and sweet.
Re: Sandpaper.
Mark Paulley
Phillip,
New people bring new ideas and we ALL learn!!! Welcome and kept writing!!!!
Sometimes a new person will ask the questions in a way the more experienced people may not have thought of and guess what the light bulb goes off and we find a better or fun way to see or accomplish things in this craft.
Re: Sandpaper.
Dick Hines
Phillip, that would work, I guess. I flip a sheet of paper over close to the bottom to remind me to get more paper but then I get in the middle of finishing a piece and don't get the paper.
I guess I will have to do better.
Re: Sandpaper.
Emmett Manley, Lakeland, TN
Prices are much better for Norton 3X at Sanding Glove than at Hartville Tool, even considering the free shipping at Hartville. Also, Sanding Glove offers an assortment of 26 sheets of seven grits of Norton 3X.
Re: Sandpaper.
Steve Worcester.
Based on this, I am guessing you are using sheet good, hand held.
Have you tried power sanding?
Re: Sandpaper.
Phillip Medghalchi
Dick, that can get confused in the middle of working with the assumption that yo just lay it there. with hours of working and looking at the same color a change of color to red which is warning will draw your attention, plus it's a visual reminder, because you do not have anything in red in that place. Just an idea. I am guilty of it myself, but then I read somewhere that something colorful will also give yo a visual reminder. Just a thought.
