REAL MILK PAINT
Teapot
Teapot
Teapot
Larry
Any good ideas on how to turn a Teapot?
Thanks,
Re: Teapot
Re: Teapot
Craig Daymon
There's a video of the process on Youtube somewhere. I saw it quite a while ago. Quite long, part of a club demo, maybe 20 minutes or more.
Re: Teapot
Dennis in Southern Oregon
Re: Teapot
Michael, some very elegant teapots have been displayed here in the past, most notably, ones by Michael and Cynthia Gibson. Most of these involve prodigious amounts of hand carving. However, it is easy to make a turned teapot of more or less classic design with very little carving as follows. Turn and hollow a pot body and lid of the desired shape. For the spout, turn and hollow a piece in the shape of a fat drumstick and then saw, carve and sand the big end at an angle to match the side of the pot and tilted at the desired angle. For the handle, turn a ring from a cross-grain piece of the same wood and then cut an appropriate section of the ring and and carve/sand to fit the body of the pot. Finally, glue the spout and handle in place, using pieces of dowel if you like. Clearly you will need to lay out the design on paper first to determine the best dimensions for the components.
Dennis
Re: Teapot
Re: Teapot
Guy Bratt
I would imagine that by the handle would prevent getting burned :D
