1/2'' bandsaw blades
Bob Conrad
Hello
Looking for a 1/2'' 131 1/2'' blade for my grizzly 17'' 2hp bandsaw.
For cutting bowl blanks and general use. I would appreciate any
recommendations and the best place to purchase.
Thanks
Bob
Re: 1/2'' bandsaw blades
D. Hansen
try Itura designs. I think they are in Florida. Know all about all bandsaws
don stephan
many people very particular about their bandsaw source. I have always been happy with Timberwolf/Suffolk. their green wood blade is 1/2" x 3 tpi but I can't remember the tooth shape they recommend.
John Veerkamp
I used to use Suffolk/Timberwolf but then I found Supercut in Rathdrum Idaho. Made in the USA and very high quality. They are very helpful and orders arrive fast. They also cary many hard to fine types like ones made for three wheel saws. Their phone is 800-356-9918.
Jeff Smith
I've been using the woodturner's blades sold by Highland Woodworking for the last couple of years. They cut very clean, have a larger than normal set that leaves a wider kerf that doesn't closeup as fast as some in very green wood. They seem to last a little longer, too, but then I don't use my bandsaw for very much of anything but prepping greenwood blanks.
robo hippy
Lennos diemaster bimetal blades, hands down. They are commonly sold in places that weld them to size for you. I have had a couple of friends switch from Timberwolf to the Lennox blades after trying them. A bit more, but longer lasting, and if you have a good saw shop, they can be resharpened many times. They do have a home web site, but I found it really hard to navigate.
robo hippy
Ron Bauer
I also switched from Timberwolf to Lennox. The TW's had some "lumpy" welds that I didn't like. R.
I don't believe in using high dollar blades for cutting green wood. I use cheap blades from my local saw sharpening service. It's far to easy to get a catch a d bend and ruin a good blade. Especially if your new at doing this and don't have a top of the line saw.
If the wood is not sitting perfectly flat it can rock and grab the blade. If you force the cut or the saw doesnt have the right tension the blade bows I. The cut and can grab and bend.
My blades cost about $6 for 105" and $12 for 151". I can just toss them if they get bent or dull
Bill Nixon
I have the same saw and get timber wolf blades from Grizzly.
