Piercing and wood choice advice please
ken chase
Returning to turning after a long absence. Want to turn very thin wall
vessel for piercing. What wood is best choice and where is the best place to purchase? I prefer dry wood and live in Palm Desert.Ca and previously have used
mesquite. I believe not the best choice for this type of work.
Thanks Much
Ken
Re: Piercing and wood choice advice please
Dick Coers
It's my experience that turning thin dry wood doesn't work well. The wood can go into a resonance and crack. I just proved it a week ago in hard maple. Internal cuts going pretty well, but I got that resonance up near the opening of the vessel. I shut off the lathe, and had 3 cracks radiating from the opening. Wet red maple and box elder are my favorites. If you've been off the lathe for a while, you're jumping back on the saddle of a tough bronco!
Ken Turning thin is fun. First off it's hard to find reasonable sizes in Dry wood unless you want to turn under 4" in diameter. Most turners will turn green wood either to final thickness or rough turn the piece, let it dry and then return it to the final thickness. If you want it to stay as close as possible to round the twice turn method is the way to go. However a lot of turners like John Jordan and many others simply select the wood out of the log at the proper place and then the warping is kept to a minimum or simply isn't a problem with their design.
One thing you have to deal with is keeping the wood wet while you hollow so it doesn't get external cracks from drying too fast.
If you new at hollowing one of the Captured boring bars is the way to go. (I use a homemade copy of Lyle Jamiesons) It takes all the white knuckle stress out of hollowing and if you use a laser it takes the stress out of measuring wall thickness.
to answer your question about what wood is good for turning thin, it would probably be easier to ask what woood won't turn thin. Just about every species I've worked with can be turned thin enough to pierce. Wood with defects or bark inclusions may fall apart when turned thin but I've seen some wonderful pieces turned this way. I would also think if you plan to pierce much of the surface you wouldn't want highly figured woods because it would simply be a waste. Malcom Zander's pieces for example have almost no wood left after piercing.
Lyle Jamieson
Lyle Jamieson
I agree with John and thanks for mentioning the tool system. The most important thing for piercing is to get a thin uniform wall thickness. If it is not 1/16 inch or so the piercing will be very difficult and frustrating. The laser makes the thin wall fast and easy. The wood is secondary, almost anything will work. Keep it wet. The finer grain woods will work better then course grained woods like oak. Enjoy the ride.
