woodcut bowl saver
cranskin
I recently purchased the woodcut bowl saver,but they no longer have templates for depth of core. Does anyone have the dimensions for making those templates? Thanks,Lynn
woodcut bowl saver
cranskin
Re: woodcut bowl saver
Dick Coers
I didn't even know they had templates. I've had mine for a long time, I know they didn't have them when I bought it. I mark out the diameters I want to cut on the face of the blank, locate the center of the pivot slightly off center towards me, then measure from the face of the bowl minus the depth I want to cut.
robo hippy
They used to have a laser pointer hook up that would point out the depth for both blades. Not sure if they have that any more or not. You could make plywood spacers for distance away from the headstock, or use calipers for the depth. Big blade is 5 inch radius, small blade is 4 inch radius. I have the old template for the spacers, and found them pretty lacking....
robo hippy
Another tip
Dick Coers
You can "stretch" the capacity of these a little. It's pretty east to pop a 1" diameter post on long grain wet wood bowls. So I place the center of the pivot at least 1/2" off center. That way when you hit the stop on the pivot, you will have that post to pop off. I've also cheated the knife a little too. I set the knife to the recommended position for the entire cut. But if it's stubborn to pop, I move the knife over a 1/4" and make the cut again. It's often enough to bring out the blank. You can take out modified cone shapes if you set the center of the pivot on the far side of center. You'll loose capacity for diameter, but you gain a different shape.
Re: Another tip
Brad Packard
The Woodcut Bowl Saver instructions have the template shapes printed on the middle two pages. If you open up the manual at the center you should find them. Make a copy on a xerox or pull them out and make a template out of 1/4" plywood or other thin stable material.
Re: Another tip
Lyle Jamieson
Nice to see you lurking around here Brad. Don't remember you posting before.
Don Orr
I found the instructions on their website but did not find the template mentioned therein. I have this tool and made templates from thin plywood and they seem to work well for me. I'll bet if you email them they will be happy to send you a copy of the template so you can print it out and make your own. If not, I will look for my set of instructions a get you a copy. They say you can use calipers but the method is unclear. Let me know if I can help, it's a good tool.
cranskin
Hi Don, My set of instructions did not have the templates,so I would greatly appreciate it if you find yours could you send me a copy of the templates. Thanks again. Cranskin@yahoo.com
I'll see what I can find.
Template sent via email
George Taylor
File too large to post.
Nice to have you appear Brad, and....
JamieDonaldson
...was looking through your new catalog last night. You've come a long way from the first edition years ago!
Thanks George !
Don Orr
I couldn't find my instructions but have my wooden templates that my wife scanned and sent to me as a file but it is not the best copy.
