some new shapes I've been playing with
Mike Potts
I had some box Elder that seemed to small for bowls, so i thought I's try some natural edge vases.
they start from left to right in turning order
this is the second one I'm happy with it shape and the wat the flames came out.
the third one I like the way the top came out but I'm not happy with the shape of the base or cove. I'm thinking of making the base smaller in diameter and changing the cove shape both from base and the bowl. any comments are welcome
Thanks
Mike
Re: some new shapes I've been playing with
Dick Coers
I love the natural edges, but not a fan of any of the bases. When the base is as big, or nearly as big as the rim, it just looks too heavy. You have the chance to really have some drama here, but those heavy bases just seem to kill the form.
Ditto what Dick said. The tops look good. Well actually the overall turning is good but the design of base needs work. I would make each one smaller. I like the shape of the one on the left. The one in the middle would be a lot nicer with a much smaller bead and base. Same with the size of the one on the right. Overall going in a very good direction.
Changes made
Mike Potts
I couldn't do anything with the one on the right or the middle one, but I did change the one on the right. After Before
I'll let it dry for a couple of days then put a food safe finish on it, cause you know someone will be eating their Wheaties out of it. Oops that's a different thread
Mike
Re: Changes made
Phillip medghalchi
Mike, do urself a favor & read up on golden rule. & don't buy the gauge, there are instructions on how to make it, that helps you to refine your designs then down the road, your eyes will automatically tell the shapes.
Re: Changes made
Phillip medghalchi
Keith Tompkins
Keith Tompkins
Hi Mike, If I could make a suggestion, the natural edge is very organic and flowing, and the form flows until it approaches the sharp, abrupt change above the bead, and below the bead. Better, I think, to continue flowing curves, eliminating the sharp breaks, right up to the bead. If you make the foot about the same thickness as the thickness of the rim, the overall appearance would be enhanced. Just my opinion, of course. :D
